Idle Mix Screws
  • Toolmaker Tim
    • 671
    • South Bend, Indiana
    Idle Mix Screws
    Does anyone have any thoughts or ideas as to why the idle mix screws are brass? With all the issues of idle screw ports being plugged by broken tips, wouldn't 300 series stainless be a better choice? I realize it is tougher to machine, but other than ease of machining and corrosion resistance, is there a reason soft brass is used?
    1979XS1100SF
    K&N's and drilled airbox
    Jardine 4in1
    Dunlop Elite 3's
    JBM slide diaphragms
    142.5 main jets
    45 pilot jets
    T.C.'s fusebox & SOFA
    750/850 FD mod.
    XV 920 Needle Mod.
    Venture Cam Chain Tensioner
    My guess is cost. When your running that many parts through the line at a time, it counts. And brass is sturdy enough to do the job.
      Besides the reasons already mentioned, SS will also seize in aluminum much, much easier than brass.
