Eletrical problems
  • kevinboylan1989
    • Jul 2010
    • 17
    Eletrical problems
    I'm having a little bit of a problem with getting spark. I only get spark once every time I turn the ignition on. What would cause this?
  • petejw
    • 2269
    • sydney australia
    what model bike have you got?
    if its the early model fitted with a ballast resistor
    that could be causing ur problems,
    its situated under the tank on the left hand side
    rail, disconnect the 2 wires and join them together
    then try starting it, also be sure to have a good charge
    on ur battery.
    good luck with it.
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
