Timing adjustment???
  • wrench78
    • Aug 2010
    • 7
    • East Bay, Ca
    I am fairly new to riding and motorcycles in general, and have learned that my "shade tree" mechanics knowledge is fairly useless with my '80 XS 100 G. I have an engine noise that almost sounds like a knocking rod, but I think it is not loud enough. A couple of people have told me it sounds like my timing is off, but I am unsure on how to check that. Any help?
    In comparison to other engines these have a lot of top end noise from the valve train. I would suggest just doing a valve shim check and adjust it necessary before trying to adjust timing. Could also check the cam chain tension.
      Timing Show-N-Tell...
      Here's a video of the timing being checked/set:
      Courtesy of Member/Guru here 3Phase.
      • dbeardslee
        • 4385
        • Maineville, OH
        +1 on camchain tension. Check that first - supposed to be done every 1k miles, and the engine will be a lot noisier on top with an improperly adjusted chain. My $.02
        • petejw
          • 2269
          • sydney australia
          an out of sync carb
          can cause a knock,
          wouldnt hurt to check to see if
          the carbs are synced.
          couldnt see that the timing would cause
          a knock especially if its knocking at idle,
          in saying that it still wouldnt hurt to check it.
          pete
          new owner of
          08 gen2 hayabusa
          former owner
          1981 xs1100 RH (aus) (5N5)
          zrx carbs
          18mm float height
          145 main jets
          38 pilots
          • Pat Kelly
            • 3046
            • Golden Valley, AZ
            If the vacuum 'advance' hose is connected to a carb boot nipple instead of the nipple on carb #2 then it can cause the vac adv mechanism to "flutter" or bounce, causing a rattle or knock at low (idle) RPM.
            Just another (easy to fix) possability
            Pat Kelly
            <p-lkelly@sbcglobal.net>
            1978 XS1100E (The Force)
            1980 XS1100LG (The Dark Side)
            1999 Suburban (The Ship)
            1994 Dodge Spirit (Son #1)
            1968 F100 (Valentine)
              Flutters and Bouncing at Low Rpms...
              Yup! And even when it is connected correctly it makes noises at low Rpms...
              • wrench78
                • Aug 2010
                • 7
                • East Bay, Ca
                Thanks
                Thanks for all of the input and advice. Will definitely let you all know when I have it dialed in!
                • tcoop
                  • Nov 2009
                  • 793
                  • South Weber, UT
                  An exhaust leak can also sound like a knock from the top end.
                  Ty
                  78 XS1100E - Now in Minnesota
                  80 XS1100LG - The Punisher
                  82 XJ1100 - Daughter's Bike
                  • wrench78
                    • Aug 2010
                    • 7
                    • East Bay, Ca
                    Hve checked the cam chain tension, and the sound remains. Will check the valves next, but I feel nothing from putting my hand on the valve covers. Bike runs strong, but I have concerns.........
                      • 8930
                      I also agree an out of sync carb will produce a knock sometimes, BTDT. Also you can try a thicker oil. I had a motor once that I had to run 70W in it to quiet the knock. Try 40W or 50W. JAT
                      • wrench78
                        • Aug 2010
                        • 7
                        • East Bay, Ca
                        How do I find intstructions on how to properly check and adjust valve shims??
                          Resources for the How-To Owner?
                          how 'bout this:
                          It's c-Bug's website where you can download the repair manuals which cover the step-by step of the valve clearances check/shim selection and....
                          everything else that you're gonna wish you have the repair manual for.
                          (Not a bad idea to skim through his musings bout his bike either. I thought it was a good read...)
                          Last edited by Larrym; 12-14-2010, 06:16 PM. Reason: C-Bug: The man and his machine.:-)
