XJ11 Airbox removal
  • KA1J
    • 664
    • Groton, CT
    XJ11 Airbox removal
    I'm removing the airbox tomorrow. Is there anything I should know to make it as easy as possible? If there's something I should do in a particular order, that would be helpful to know.
    Thanks!
    Gary
    From what I have herd is XJ's, it will be a fight.
    • Cobia
      • Jul 2007
      • 1587
      • Palm Beach County, Fl
      Gary,
      To remove the airbox from an XJ you will definitely have to remove the carbs first. Once out it will be easy. Just remember to install a filter on the end of the crankcase breather hose if you're going for pods.
      1980G Standard, Restored
      Kerker 4 - 1
      850 Rear End Mod
      Automatic CCT
      1980GH Special, Restored
      '82 XJ1100 (Sold)
      • yamahansolo
        • Aug 2007
        • 1113
        • jawga
        Myxj air box was easy. Seemed just like my xs
        79 xs11 standard
        8mm msd wires
        tkat fork brace...
        Fox shocks...
        mikes650 front fender
        led's gallore...
        renthal bars
        gold valve emulators
        vmax tensioner
        Rifle fairing
        • KA1J
          • 664
          • Groton, CT
          It was more effort than I expected. I pulled the intake manifolds but that wasn't enough (& those little buggers are deep inside that box). I had to remove the air intake horn& that was a bugger to pull out as it's thicker & wider inside than what's outside (Same for the intake boots). I then removed the carbs and the box came out.
          It'll be a bear to get back in if I have to replace the boots/air intake horn in the reverse order.
          Hopefully I'll have great results with the pods & a jetting change and the airbox will be happily set safely aside to give to the next owner whenever that happens.
