This site will be temporarily offline this Friday April 18th from approximately 5pm PST (UTC-7), for a few hours or less (hopefully) for upgrades. See this post in Forum Announcements for more info.
I'm removing the airbox tomorrow. Is there anything I should know to make it as easy as possible? If there's something I should do in a particular order, that would be helpful to know.
Thanks!
Gary
From what I have herd is XJ's, it will be a fight.
1978 XS1100E K&N Filter
ATK Fork Brace LED Dash lights
Ammeter, Oil Pressure, Oil Temp, and Volt Meters Green Monster Coils SS Brake Lines
Gary,
To remove the airbox from an XJ you will definitely have to remove the carbs first. Once out it will be easy. Just remember to install a filter on the end of the crankcase breather hose if you're going for pods.
1980G Standard, Restored
Kerker 4 - 1
850 Rear End Mod
Automatic CCT 1980GH Special, Restored
Stock Exhaust, New Handlebars, 1" Spacer in Fork Springs, Automatic CCT, Showa Rear Shocks '82 XJ1100 (Sold)
79 xs11 standard
8mm msd wires
tkat fork brace...
Fox shocks...
mikes650 front fender
led's gallore...
renthal bars
gold valve emulators
vmax tensioner
Rifle fairing
It was more effort than I expected. I pulled the intake manifolds but that wasn't enough (& those little buggers are deep inside that box). I had to remove the air intake horn& that was a bugger to pull out as it's thicker & wider inside than what's outside (Same for the intake boots). I then removed the carbs and the box came out.
It'll be a bear to get back in if I have to replace the boots/air intake horn in the reverse order.
Hopefully I'll have great results with the pods & a jetting change and the airbox will be happily set safely aside to give to the next owner whenever that happens.
