blinker problem
  • petejw
    • 2269
    • sydney australia
    blinker problem
    now there working, now there not,
    now there working, now there not.
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
    • 3193
    Are they working now? How bout now? Maybe now? Now are they working?
    • lee_dutcher
      • Apr 2009
      • 822
      • mason city iowa
      mine dont work either. maybe someone else will chime in about your (and mine) problem... but seems for you you have a bad connection somewhere. go through the connections and clean them well and then check your grounds as well. after that if they still dont work maybe flasher?
      1980 gs1000g "stock"
      • ManagerMike
        • Mar 2010
        • 445
        • S.E. Michigan
        Flasher. Good luck finding an O.E. version that will work with the auto cancel feature.
        '78 E "Stormbringer"
          Self canceler can cause the same..........working........not working..........working........
          • cywelchjr
            XS-XJ Super Guru(Deceased)
            • 4450
            • Sacramento, CA
            Also if you have the 4 ways, the switch for those can have the solder joints come apart and cause exactly that type of problem. If it's the problem you can open up the switch and you will find loose wires, just clean up the connectors and solder them all back on (and likely do this with ALL of them even if they seem ok) and put it back together and if you did it right everything will be fine again.
            • b.walker5
              • Feb 2009
              • 1745
              • Invercargill, New Zealand
              Ummm, they're blinkers... Can't see the problem...
              • petejw
                • 2269
                • sydney australia
                sorry lee,
                i was only joking,
                theres nothing wrong with my blinkers. lol
                pete
                new owner of
                08 gen2 hayabusa
                former owner
                zrx carbs
                18mm float height
                145 main jets
                38 pilots
                • lee_dutcher
                  • Apr 2009
                  • 822
                  • mason city iowa
                  ha ha ha... i got mine working it was the switch... so i just picked up a "universal one" ans wired it up...works good
                    Unless the parts are physically broken, you can repair the OEM switch. There are several contact points that get corroded and a few solder points that may need to be re-soldered. Once you get it apart and cleaned, lube it with dielectric grease, and it should work just fine.
                    Of course, if you are just gonna toss the OEM switch, I'd be happy to take it off your hands!
