Exhaust types
  • Rickrod3
    • Jun 2009
    • 721
    • Oakland, New Jersey
    Exhaust types
    What are the pros and cons of 4 into 1's Vs 4 into2 's.?
    I have some time but; I'm on the look out for an exhaust for an SG.
    For what some used exhausts are going for (Givin the condition)
    When the time comes; I may bite the bullet and get a new set.
    Any advantage to a stock set?
    I'm interested in what worked and didn't from the XS11 collective.
    Thanks in advance
    Rick
    650SF
    XS1100SG Project bike
    Well good and bad news. Bad news is the only thing you can buy new is the Mac systems. They are nto considered the best quality out there.
    Good news is, watch ebay and from time to time a system will come up. Sometimes stock, sometimes Jardine or Kerker even.
    4-2 is the stock setup and works best with stock jetting and stock airbox setup.
    4-1 gives better performance, but you lose some of the low end performance. Typically, it is used with POD filters. And requires some carb jetting changes
    • mro
      • 4276
      • Hayward, California
      "Reconditioned" stock exhaust
      The exhaust on this SF was in pretty sorry shape.
      Headers were badly pitted, collectors rusted and a few small dents and some rust on the muffs.
      I spent over twenty hours grinding, filing then sanding just to get them smooth.
      Then fixed the dents etc..
      Then painted with some 1200 degree paint.
      BTW, after just three/four months I was not happy with them so now it's powder coated.
      mro
        The OEM 4-2 systems all featured a crossover arrangement which helps with power; this is missing from the aftermarket 4-2 systems. As DG said, a 4-1 will give you a power gain on the top end but at the expense of the lower end.
        The original exhaust (particularly on the standard models) is a very well thought-out piece. In terms of the most power at the most points on the 'curve', you can't do any better. Finding a OEM system in decent shape is a problem, although they are out there. For your F, any 'standard' model exhaust '78-80 will fit. Can't find one? Got the remains of yours? Here's the slickest mod IMO I've seen for standard.... http://www.xs11.com/forum/showthread...ler+mod&page=2
        Looks almost stock, and he retained the crossover.
        The 'Special' OEM exhaust will need mods to the bike, pipes, or both to fit your F due to the different angle of the mufflers.
        • Aches n Pains
          • 349
          • Reston, Va.
          Useful post
          This is a great post re: lots of different exhausts. Most are not available new but it gives you a good idea of what you're looking at.
          1995 KZ100P
          Pods, jets, pipes, cam adjuster, oil cooler
          1977 Ironhead - custom build
          Hot engine, custom frame, KZ front and rear, high torque starter, alternator conversion, Progressive shocks, Thunderheart wiring, Dyna ignition, oil cooler, Dakota Digital instruments, etc.
          Sold all my XS's to Eastcoaster but still love to keep up with you guys. This is the best cycle forum on the web.
          • Rickrod3
            • Jun 2009
            • 721
            Good place to start
            For My riding style I would be better served with a stock exhaust.
            I will research bringing back a set.
            BTW. The pipes are for an SG the one I picked up from Russ.
            I have been meaning to change my signature to show this.
            I would be helpful to me if someone could tell me which models would also fit an SG. Would a Set from a 3H3 (79 Special I think) fit?
            Thanks
            650SF
              All of the Specials had the same exhaust. The only difference being that the Midnight Specials had their exhaust systems finished in a black chrome.
                Here's one here: http://cgi.ebay.com/ebaymotors/Yamah...item2c57b5dc06
                Not the best I've ever seen, but not bad for the price either...
                • Rickrod3
                  • Jun 2009
                  • 721
                  mro
                  Nice job on the pipes.
                  Did you encounter much rust through the pipe wall?
                  What did the powder coat cost?
                  650SF
                  • zoom4100
                    • 8
                    • Utica NY
                    exhust
                    there is a place in PA. called Jet Hot and they will put a ceramic coating on you exhust system they have black chrome and chrome once you put this coating on yopur pipes won't blue and you can whip off grease without staining. Phone # 1-610-265-0202
                    • Rickrod3
                      • Jun 2009
                      • 721
                      Thanks Zoom I'll notr the number
                      650SF
