81 LH oil pan
  • 81 LH oil pan
    Anyone know if the oil pan was painted black originally?
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    ive got the 81 sports version,
    similar to the midnite without the gold,
    and the oil pan isnt painted, if thats any help.
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
      I just bought one on eBay. It is not painted.
      http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWNX:IT
      David
      1981 XS1100 Special
      Previous Bikes
      1999 Honda Goldwing Aspencade 1500
      1983 Honda Goldwing Aspencade 1100
      1982 Honda CB900c
      1984 Honda vt750 Shadow. My son's bike now.
      1984 Honda vt500 Shadow
        Mine is all original. The oil pan is not, but the filter cover is painted black.
        XJ1100 Ruby Red
        XS1100LH "Midnight"
        1972 MGB Roadster "sold"
          Yamaha fitted that same part to all the XS11s, 2H7-13417-00-00, it's not painted.
          Brian
            Good news
            Thats good news for me. I thought the PO may have done some tinkering or hit something and needed to replace the pan. Finding several odd things as I'm stripping it down and this was one of them.
            mack
            HERMES
            original owner
            81 XS 1100 LH MNS
            SPICA
            78 XS 11E
            IOTA
            613-398-6186
              Hi Mack,
              had so much fun with the 79 you are doing an 81
              Please keep track of all the subtle differences as there will be questions from others later.
              Are you coming to the big city for the Toronto Motorcycle show in December?
              it would be good to meet up again.
                Got the disease
                Ya Phil, seems I got the XS bug restoring Hermes. Just seems such a shame to let one of these bikes sit and rot away because the PO hasn't the ability to bring them back to life. Just couldn't pass on this one. Not too far gone, just have fix some mistakes the PO made and get rid of the barn rust. Not sure what I'm going to do with the gold though. No one around here does gold plating.
                mack
                HERMES
                original owner
                81 XS 1100 LH MNS
                SPICA
                78 XS 11E
                IOTA
                613-398-6186
                  Gold powder coating is actually more durable. Neither one is the "correct" color, but if you do all the parts, no one will notice unless they really know what to look for.
                    Gold plating
                    Have you done it Bug?. What's involved with the prep for the powder coating. Bead blast all the pieces, sand smooth , then epoxy before paint?
                    mack
                    HERMES
                    original owner
                    81 XS 1100 LH MNS
                    SPICA
                    78 XS 11E
                    IOTA
                    613-398-6186
                      I have not, but ex-member Bigfoot did. Didn't turn out too bad! The nice thing about powdercoating is that it fills in the rough spots, and actually does BETTER when the surface is not glossy smooth. The only issue is that the gold is translucent, so you do have to have the surface clean.
                        ...Not sure what I'm going to do with the gold though. No one around here does gold plating.
                        Check locally for 'window tinting' services. Many of these guys offer a 'gold plating' process that applies a 'gold' finish on auto trim, don't see why this wouldn't work for you. You may have to have the parts re-chromed if the plating is damaged badly, but maybe not.
                        I don't think powdercoating will give the results you're looking for; I've tried some 'chrome' powdercoat and was less than impressed. The finish resembled a polished aluminum surface (with a milky clearcoat) more than anything, and shows scratches worse than 'regular' powdercoat, and much worse than paint. And unlike paint, it's nearly impossible to 'touch-up' or rub out defects in powdercoat.
