Anyone know if the oil pan was painted black originally?
81 LH oil pan
81 LH oil pan
mack
79 XS 1100 SF Special
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
https://youtu.be/wB5Jfbp6SUc
https://youtu.be/RaI3WYHSuWA
Frankford, Ont, Canada
613-398-6186Tags: None -
ive got the 81 sports version,
similar to the midnite without the gold,
and the oil pan isnt painted, if thats any help.pete
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
[url]http://www.youtube.com/watch?v=3pA8dwxmAVA&feature=mfu_in_order&list=UL[/url] -
I just bought one on eBay. It is not painted.
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWNX:IT
David1981 XS1100 Special
Previous Bikes
1999 Honda Goldwing Aspencade 1500
1983 Honda Goldwing Aspencade 1100
1982 Honda CB900c
1984 Honda vt750 Shadow. My son's bike now.
1984 Honda vt500 ShadowComment
Yamaha fitted that same part to all the XS11s, 2H7-13417-00-00, it's not painted.Brian
XS1100 LG "Mr T", SG "ICBM" & FJ1200
Check out the XS Part Number Finder
Be not stingy in what costs nothing as courtesy, counsel and countenance.Comment
Good news
Thats good news for me. I thought the PO may have done some tinkering or hit something and needed to replace the pan. Finding several odd things as I'm stripping it down and this was one of them.mack
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
613-398-6186Comment
Hi Mack,
had so much fun with the 79 you are doing an 81
Please keep track of all the subtle differences as there will be questions from others later.
Are you coming to the big city for the Toronto Motorcycle show in December?
it would be good to meet up again.
Phil1981 XS1100 H Venturer ( Addie)
2004 Kawasaki Concours. ( Black Bear)Comment
Got the disease
Ya Phil, seems I got the XS bug restoring Hermes. Just seems such a shame to let one of these bikes sit and rot away because the PO hasn't the ability to bring them back to life. Just couldn't pass on this one. Not too far gone, just have fix some mistakes the PO made and get rid of the barn rust. Not sure what I'm going to do with the gold though. No one around here does gold plating.mack
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
613-398-6186Comment
-H. FordComment
Gold plating
Have you done it Bug?. What's involved with the prep for the powder coating. Bead blast all the pieces, sand smooth , then epoxy before paint?mack
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
613-398-6186Comment
I have not, but ex-member Bigfoot did. Didn't turn out too bad! The nice thing about powdercoating is that it fills in the rough spots, and actually does BETTER when the surface is not glossy smooth. The only issue is that the gold is translucent, so you do have to have the surface clean.1980 XS850SG - Sold
-H. FordComment
Check locally for 'window tinting' services. Many of these guys offer a 'gold plating' process that applies a 'gold' finish on auto trim, don't see why this wouldn't work for you. You may have to have the parts re-chromed if the plating is damaged badly, but maybe not.
I don't think powdercoating will give the results you're looking for; I've tried some 'chrome' powdercoat and was less than impressed. The finish resembled a polished aluminum surface (with a milky clearcoat) more than anything, and shows scratches worse than 'regular' powdercoat, and much worse than paint. And unlike paint, it's nearly impossible to 'touch-up' or rub out defects in powdercoat.Fast, Cheap, Reliable... Pick any two
