XJ11 idle adjustment knob in a bad location
  • KA1J
    • 664
    • Groton, CT
    Man, what a hassle getting to the idle adjustment knob on the XJ11. On the XJ650 with Hitachi carbs, the adjustment is behind the carbs where you can get to it easily with no effort. On the XJ11 it's in front of the carbs right where it's in a tight space and you have to brush against the lower fins & be compressed by the carbs. I have to wear gloves to contact that knob. No way to do it without gloves, I'll get burns on my hands
    Is there a trick to accessing it?
  • SFerinTEXAS
    • Jun 2006
    • 877
    99% of the time that is set when the sync is done and the tank is off. After that for a minor adjustment a long tool or stick will serve to move it a little.
    Its not something that requires a lot of fiddling with.
    79SF
    XJ11
    78E
    • petejw
      • 2269
      • sydney australia
      i havent got the xj,
      but have heard of members using a screwdriver
      to get into the idle adj knob.
      pete
      new owner of
      08 gen2 hayabusa
      former owner
      1981 xs1100 RH (aus) (5N5)
      zrx carbs
      18mm float height
      145 main jets
      38 pilots
        • 8767
        I've got a cut cable from a speedometer attached to the main idle knob, so the new knob is by the right sidecover. It makes a 90 degree bend. It nice to be able to adjust it anytime in one second.
        • Rasputin
          • 3189
          • Lacombe, Alberta, Canada
          What a clever idea! I may have to make something like that as I burn the **** out of my hands doing the adjustments too.
          2-79 XS1100 SF
          2-78 XS1100 E Best bike Ever
          • rpgoerlich
            • Dec 2007
            • 643
            • Katy, Tx
            Indeed. How about a pic showing how you attached it to the idle screw?
            Richard
            • davidsymons53
              • 197
              • Peterborough, Ontario
              I use a leather glove when I adjust the idle.
              David
              1981 XS1100 Special
              Previous Bikes
              1999 Honda Goldwing Aspencade 1500
              1983 Honda Goldwing Aspencade 1100
              1982 Honda CB900c
              1984 Honda vt750 Shadow. My son's bike now.
              1984 Honda vt500 Shadow
                • 8767
                I don't have a pic at the moment, but it's pretty simple. When you have the carbs on the bench, drill a hole slightly larger than the cable in the center of the adjusting knob (78-79 carbs) about 1/4" deep. Put some JB weld in the hole and insert the cable, letting it dry overnite. Cut the cable to the right length and attach a knob of your choice at the end. It needs a hold down on the cable behind the knob. I'll snap some pictures later. Sorry, I don't have a mod for the later carbs with the ajustment screw down below in front.
                • KA1J
                  • 664
                  • Groton, CT
                  Still, this is an idea worth considering.
                  Most cool.
                  Other solutions anyone?
                  • Yahman
                    • Mar 2008
                    • 779
                    • Salem, OR
                    I use an old potholder placed on the engine, then I can get my bare hand in there to adjust it.
                    Larry
                    82 XJ1100
                    80 XS1100G (Project bike)
                    64 Yamaha YA-6
                    77 Suzuki TS-185
                      • 8767
                      Ok, here's the pic, sorry it took so long, only 7 months.
                      • KA1J
                        • 664
                        • Groton, CT
                        Very clever!
                        • Smash
                          • Aug 2010
                          • 257
                          • Denver, CO
                          We've had to do LOADS of adjusting of the idle screw since (we realize now) the bike needed a valve adjustment. Every time we just have a long sleeve shirt/jacket and full finger gloves. Can reach in there. Karla does it better than I do, but we both have small hands (hell I'm all of 5'8").
                          Two weeks vacation does NOT make a life.
                          His: 2006 Ninja 650R, salvaged, 10k miles
                          Hers: '82 XJ1100 44.4k miles
                          • TheRev
                            • Jun 2012
                            • 235
                            • Madison, Wi.
                            Hello Phil
                            I would like to make do this to my xs1100 carbs. Could you please tell me where i might be able to find the knob and the hold down bracket you used? Thanks
                            Jared
                            1979 xs1100f
                            New Fuse Box
                            Progressive Shocks
                            Gold Valve Emulator
                            Dyna Coils
                            Electronic Flasher
                            Led Headlight
                            Led Turn Signals
                            4 Led Driving Lights
                            2nd Gear Fix
                            Auto Cam Tensioner
                            Digital Dash
                            Stainless Braided Lines
                            R6 4 Piston Calipers
                            Stainless Bolt Kit
                            Maier Fairing
                            Dyna Balancing Beads
                            Spin On Oil Filter
                            Stebel Nautilus Horn
                            Plasti Dip Rims
                            ISO Grips
                              • 8767
                              That knob came from the HELP section of the auto parts store and the hold down is just a 1/4" cable clamp from Home Depot. GL with your mod.
