progressive springs
  • jimg1au
    • 102
    • sydney australia
    progressive springs
    i installed progressive springs on my xs1100rh put the 3.5in spacer in that is required with special forks.my are the same as xs1100lh.there was all the paper work to do the job in the ctn.if not download it from progressives web site.it isnt a hard job.i have also replaced fork seals in both my h and rh.the seals are a different size.are the lh and h different too.
    jim garvey
    xs1100rh
    xs1100h
  • Robert Haller
    • 356
    • Atlanta, GA
    What's your opinion of the progressive's vs. the stock springs?
    Robert
    79 SF
    • jimg1au
      • 102
      • sydney australia
      HI
      my stock springs were 5mm under spec.the progressives dont need air and just that alone is a plus.the ride is much better as i put a tkat fork brace on at the same time.
      • uk1.1s
        • Oct 2002
        • 365
        • Surrey UK
        Boing...
        Agree with you there Jim -
        My Progressive springs and spacers went in at the beginning of the year and I really think they've improved things - although very limited mileage this year because of other glitchs and not much garage time. So the Tkat brace was a good move then?
        XS1.1 sport - Sold June 2005 :-(
        Guzzi 850
        Z1000
        • Jerry
          XS & TRUE XJ GURU
          • 3023
          • Elma, IA.
          I had Progressive springs put in during June of 2001, many thousands of miles on them since. OEM springs were sagging and needed to be replaced anyway. I had put on a Tkat fork brace earlier in the season, and together with the new springs the improvment in handling was quite pronounced.
          The XJ has a token fork brace built into the fender, so not as much improvement when Tkat brace was added, but still noticeable.
          Jerry Fields
          '82 XJ 'Sojourn'
          '06 Concours
          My Galleries Page.
          My Blog Page.
          • jimg1au
            • 102
            • sydney australia
            yep
            the ktat fork brace and progressive springs are the best solution to xs1100 front end problems
