The throttle on Banshee will not spring return back. Let go of the grip and it stays exactly where you left it. Works great for Cruise control....but not exactly safe!!
I thought it was just cable lubrication issue, or mis assembled switch and grip. So I took it apart and the cable will definitely snap back into place when not connected to the right grip. Same thing when put through the right switch assy.
slide the grip on the bars and it rolls around like its on bearings...no problems at all. But, put it all together, and it will not spring back. I've had a couple different sets of carbs installed and it does the same on both.
Any suggestions appreciated.
