XJ11 Carb (Mikuni BS34) rebuild instructions?
  • KA1J
    • 664
    • Groton, CT
    I'm going to be cleaning and rebuilding the Mikuni BS34 carbs on my XJ11 and would like to find a step by step pictoral of the process if it's posted online. I rebuilt my Hitachi carbs on the 650J thanks to a really nice writeup with photos and knew just where to look and what to do. If I could find that for these carbs I would be overjoyed.
    Idears?
    Thanks
    This thread should help. Check out the tech tips as well.
    • KA1J
      • 664
      • Groton, CT
      Thanks so much. My carbs are so in need of a rebuild.
      Cheers,
      Gary
      • Cobia
        • Jul 2007
        • 1587
        • Palm Beach County, Fl
        Welcome KA1J,
        The carbs on my J were the same way when I got it. But really, if you take your time disassembling them, then triple clean every circuit and jet with spray carb cleaner with its straw, you may be able to re-use even the bowl gaskets. Short pieces of metal guitar strings make good cleaners for those little holes in the pilot jets and the emulsifiers.
        1980G Standard, Restored
        Kerker 4 - 1
        850 Rear End Mod
        Automatic CCT
        1980GH Special, Restored
        '82 XJ1100 (Sold)
