Idle
  • rickybeaver
    • Sep 2010
    • 25
    Idle
    At what rpm should I set the idle on my 1100. Right now I have it set at about 1100-1200 rpms. Thanks:Rick
    1980 XS 1100 replaced the seat and sissy bar from a XS 1100 standard and changed the handle bars. Did not like the original bars at all.No mod at all except for a four into one header.
  • TADracer
    • 1417
    • Kenner, Louisiana USA
    Kind of depends on your model (which you do not state). But 1100 or so should suffice for most all of them. If you are setting it by the tach on the bike you are only in the ballpark anyway since it is not accurate enough to set anything. So if it idles smooth and sounds OK to you, it probably is.
    Mike Giroir
    79 XS-1100 Special
      Hi Ricky,
      FWIW, if my bike idle speed is set at more than 1,000 rpm it crunches real loud going from neutral into first.
      • Incubus
        • 1003
        • Austin TX
        That is NOT a crunch, Fred. That is NOT a hammer like thud of metal on metal when the tranny crashes into first.
        That is the sweet ping of the adrenaline valve cracking open.
        Patrick
        XS11F (Incubus, daily rider)
        1969 Yamaha DT1B
          I think Dbearslee put it best....it is the YAGES...Yamaha Audible Gear Engagement System.
