Yup, twisting and pulling has removed mine as well.
Brakes?????
mine master cylinder is made from alloy
is this not the same on the us models
pete
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
[url]http://www.youtube.com/watch?v=3pA8dwxmAVA&feature=mfu_in_order&list=UL[/url]Comment
No, ours don't look like that. Our are (at this age) ratty looking plastic that is SUPPOSED to let you see the fluid level without removing the cover (doesn't work 30 years later though).
I understand the 81 Midnight Specials have an alloy unit though, so maybe that's what the sport comes with? (only in bright not black like the Midnight).Cy
thanks cy,
mine has a little plastic window
at the front of the master cylinder,
which over time becomes opaque
and quite useless in the end. lolpete
new owner of
08 gen2 hayabusa
former owner
zrx carbs
18mm float height
145 main jets
38 pilots
I just did some work on my new XS850 this weekend, and it reminded me of this thread. The front Master Cylinder on the 850 is the same as the XS11SF. I had a REALLY nasty mess in the reservoir, so listening to the advice here, I was able to lift the reservoir off the base. There is a rubber seal in a groove that seals the reservoir against the Master Cylinder body. Mine is now leaking...
Anyone know what size that seal is? Should I be able to use a round one out of a regular O-ring kit (if so, what size?), or is it a square-sided seal? It's hard to tell since it's been squished in there for so long.1980 XS850SG - Sold
-H. FordComment
Try putting a smear of clear silicon on the reservoir base before installing...Fast, Cheap, Reliable... Pick any two
