My XJ on crutches!!???
  • Cobia
    • Jul 2007
    • 1587
    • Palm Beach County, Fl
    This could be a helpful hint/tip for someone....
    I'm restoring my XJ and in the process found myself needing to support the rear of the bike as I wanted to remove the rear wheel, final drive, swing arm, etc.
    The front was resting on jackstands and the back was supported by the rear wheel. What to do since I wanted something more solid than a motorcycle lift? Then the bulb went off!!!! Eureka!!!
    I took some measurements and found that I had a fairly straight line down from the upper shock absorber bolts to the ground.
    I then took two 28" 2X2s and drilled a wide hole half way through it and an appropriately sized hole all the way through to install it on the shock bolts, tapped them into place and put the nuts on and....... voila!!!
    An XJ on crutches!!!
    Here it is nest to the G.
    [IMG][/IMG]
    [IMG][/IMG]
    BTW - The position of the jackstands is CRITICAL!! Too far back and the bike will tilt forward on its own due to the weight of the engine. Too far forward and you chance being too close to the bend on the frame and it slipping off the stands.
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    And this is one of the reasons for needing to get deep into the frame. It's the worse of the rust I've found on the J. And it's really not bad, mostly surface rust. I suspect it's the result of an overflowing/broken battery case and acid dripping on the parts.
    [IMG][/IMG]
    [IMG][/IMG]
    Plan to resore the bike in two sections, the rear half first, then the engine and the front part of the frame.
    I'll keep posting pics of the progress.
    1980G Standard, Restored
    Kerker 4 - 1
    850 Rear End Mod
    Automatic CCT
    1980GH Special, Restored
    '82 XJ1100 (Sold)
    Yeah looks like a battery problem with the greenish yellow crap all over there. Have fin and good luck.
    I tale it you don't plan on just striping it down and redoing the whole frame at once?
      Hi Cobia,
      What did the drive shaft do to end up in a noose
        • 8894
        Yep, I'd take the swingarm off at least. Thing looks pretty nasty.
        • 79XS11F
          • Jul 2006
          • 3563
          • Ottawa, Ont. Canada
          That's exactly how I had my jack stands set up when my nearly completed bike went for a surprise nose dive. The jack stands got spit out the front and over she went when the total weight of the bike got to the point where it could happen. Now I pull strap the jack stands to the frame and install the front end first when rebuilding.
          Rob
          KEEP THE RUBBER SIDE DOWN
          1978 XS1100E Modified
          1978 XS500E
          1979 XS1100F Restored
          1981 Suzuki GS1100
          1983 Suzuki GS750S Katana
          1983 Honda CB900 Custom
          • Cobia
            • Jul 2007
            • 1587
            Nate,
            I don't plan on taking the engine out. Did it this way on the G and it turned out OK. The frame and swingarm are really not bad at all, just surface rust. Nothing a wire wheel can't handle.
            Maximphil,
            It has always been cautioned about not letting the swingarm drop down to the ground and hyper-extending when doing this process. I guess it stresses the u-joint and boot. So, I hung it the best/easiest way I could.
            79XS11F,
            OUCH!!!! Good idea about strapping the frame to the jackstands. I'm going to do that today, particularly since I'll have a bunch of trick or treaters roaming the neighborhood and possibly walking around the bikes. Thanks for the idea.
            BikerPhil,
            Yeah, I guess I'll have to take it out. It'll make it easier to paint as well. Actually the shaft, splines, and swingarm bearings are really well packed with grease. Found no suspect splines either.
            Might enlist your help in pulling the shaft if I get stuck.
            Thanks all.
            Kerker 4 - 1
            850 Rear End Mod
            Automatic CCT
            '82 XJ1100 (Sold)
              Hey Cobia,
              Nice rig you set up. As to the drive shaft, once you pull the four bolts holding the u-joint to the middle drive output it and the drive shaft will slide out with the swing arm. If you want he shaft out anyway, I take a piece of 12 ga wire , like one leg out of a 2 wire romex piece, wrap it around the bell of the driveshaft, grab it with pliers and use a rubber mallot on the pliers to drive it out. Works like a charm every time.
              • Electronhammer
                • 54
                • Central Illinois
                Very nice. Way to be inventive. Do you have an engine stand to support the engine when it is out of the frame, that will still allow you to easily and safely work on the engine?
                1980 CB750K
                • Cobia
                  • Jul 2007
                  • 1587
                  Thanks Don,
                  I plan to go the four bolts on the MD flange to get the shaft out. I think it'll be a lot easier to re-install as well.
                  Bikerphil and I went the wire route when he showed me how to do the FD mod a while back. He also had a right angle screwdriver that was very helpfull.
                  Hammer,
                  I don't plan to take the engine out since it really doesn't need any repairs, just cleaning and paint, same with the frame.
                  Kerker 4 - 1
                  850 Rear End Mod
                  Automatic CCT
                  '82 XJ1100 (Sold)
                  • Cobia
                    • Jul 2007
                    • 1587
                    XJ Frame up Resto Update
                    I really wasn't going to go radical on this bike but with the exortation of several members.... Thanks Phil!! And since the rest was only a few bolts away I decided to pull the engine from the frame and go all the way. After removing the wiring harness, actually the scariest part of it , the swing arm, etc. I used what I call the cow tipping technique to remove the engine from the frame.... or is it the other way around.... well, never mind, I separated the two.
                    I then transported the engine and frame to our boat storage facility where we have a compressor and other useful items such as an engine hoist, etc.
                    My goal is to sandblast everything (easier and kinder to the parts than a wire wheel on a drill or a grinder) in preparation for priming and painting.
                    Here are some pics after sandblasting the engine:
                    [IMG][/IMG]
                    [IMG][/IMG]
                    [IMG][/IMG]
                    [IMG][/IMG]
                    [IMG][/IMG]
                    And here it is after an acetone wash and primed for paint:
                    [IMG][/IMG]
                    [IMG][/IMG]
                    [IMG][/IMG]
                    [IMG][/IMG]
                    After waiting for over an hour for the primer to dry, I then went ahead and painted it with the 500 degree DupliColor Semi Gloss ceramic based paint.
                    [IMG][/IMG]
                    [IMG][/IMG]
                    [IMG][/IMG]
                    [IMG][/IMG]
                    I'm really not looking for a very shiny coat of paint on the engine, thus the semi gloss (satin) finish coating. I don't want all the maintenance of keeping the engine all farkly (sp?) and shiny, more like the finish on the FZ1 and R1. The shiny finish is going on the frame and other exterior parts. But one very cool thing I noticed was that the ceramic particles actually look like metal flake once the paint is dry, it's a very cool look, deep dark semi gloss black with these silver metallic particles lurking underneath.
                    I'm semi-considering sanding the ends of the fins and the ridges of the valve cover but since my finish is semi-gloss and not glossy, I don't see where I could find a matching clear coat. Afterall, I don't want oxidation to take hold on the sanded and polished fins and then proliferate thought he paint job.
                    Well, the sandblasting took about a day or two, and the degreasing, acetone wash, priming, and painting took one day. Sure beats the hell out of wirebrushing!!!
                    Next are the frame, swing arm, center stand, kick stand, final drive, calipers, etc. If you're interested, I'll keep posting pictures of the progress.
                    There's this really wild metallic paint I'm considering for the headers and the can. I'm just wondering what the max temperature the headers endure and whether this paint will withstand it.
                    Not bad for a rattle can job so far!!!???
                    Kerker 4 - 1
                    850 Rear End Mod
                    Automatic CCT
                    '82 XJ1100 (Sold)
                      • 8894
                      Looks real good, Bro. That bike is going to be sweet, keep the pics coming.
                        Looks AWESOME Cobia!! I'd be happy to call that engine mine!! With this as the starting point, the rest of it has got to look amazing when done!! Keep posting the pics, now I'm sad I do not have a winter project!!
                        • justme1100
                          • Jul 2008
                          • 243
                          • Eagle, WI
                          Nice, let us know how the paint holds up. I am thinking I will use the 1200 deg. paint just to be on the safe side. I have had good luck with the BBQ paint I have used.
                          Just ME and my 82 XJ 1100. Mac 4>1-2 1/2" open baffle shotgun, no octy, K&N pod filters, LED tail/brake light & directionals, 750 FD mod, Ear Cannon air horn, modified bars and dash. "Motorcyclists are all bound together by a brotherhood tie through their love of the sport, and what difference does it make what machine he rides as long as he belongs to the clan." Walter Davidson, Dec. 1920 edition of Harley-Davidson Enthusiast Magazine http://s851.photobucket.com/albums/ab78/justme1100/
                            I agree! Keep the pics coming as you go!
                            • Cobia
                              • Jul 2007
                              • 1587
                              Thanks Phil and Don,
                              I'll keep the pics coming as best I can with dirty and paint laden hands..lol!!
                              Hey Don,
                              I hope you're healing well and on the fast track to a quick recovery. A winter project might help that along!!??
                              I've been lucky that the weather has been ideal for this type of work, temps in the high 70s to low 80s and humidity in the mid 60s. Paint dries fast, keeps runs to a minimum. It's a biatch getting all those fins coated properly from all angles, I've had to turn into a contortionist to do it properly. Hope I find a honey that will take advantage of these abilities!!! He, he...
                              Kerker 4 - 1
                              850 Rear End Mod
                              Automatic CCT
                              '82 XJ1100 (Sold)
