My first project
  • petejw
    • 2269
    • sydney australia
    #106
    hi stevestrom,
    just a cpl of things came to mind,
    an engine burning oil makes it really hard to read
    plugs, can be hard to tell the difference between a sooty
    plug and a plug carbonised with burnt oil,
    a rich or lean condition can foul a plug with a smokey engine,
    if the engine is running lean
    it will run much hotter, things expand more than they should
    and the oil begins to thin out fouling the plug.
    the plugs u have pictured tho, all 4 look different
    when u rebuilt the carbs did u use all stock settings?
    did u sync the carbs when u put them back on?
    are all float levels exactly the same?
    when u honed the engine, did u give the cylinders
    a nice cross hatch pattern?
    this is important for the rings to seal correctly.
    with the head, did u replace the valve guide seals?
    when u checked for leakage did u fill the ports with fuel
    to check for seapage between the valve and seat?
    other than the smoke, how is the engine running?
    if the bike seems to be running good enuff to ride,
    id be runnng the engine in as soon as you can,
    starting and stopping a rebuilt engine isnt good as
    the chance of the cylinders glazing becomes greater.
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
      #107
      Originally posted by stevestrom
      The numbers you are getting on your engines seems really high, I have little experience with this stuff but from what I have read these engines should be around the 150psi mark when warm. Don't the numbers go up as the pistons expand in the cylinder? I wonder how high your numbers would climb with a hot motor and a little oil?
      I'm personally not sure a warm engine will translate into higher numbers. Yes, you should get better ring seal if the motor is warm, but you've also got the factor of how much the aluminum cylinders/head 'grows'. I know on Harleys that their cylinders can get up to .1" longer from full cold to fully warmed, so that will affect compression ratio quite a bit. If the rings are sealing, oil makes little difference in the numbers.
      Are my numbers really high? Can't say for sure, as I'm not quite testing under the same conditions as if the motor was in the bike. It was mentioned that carbon build-up can cause high numbers, but I doubt if it would cause them to go that high without showing problems. None of the plugs that I pulled showed any signs of detonation or other distress that you would expect if the compression ratio was excessively high.
      But after running these tests, I'd say you just need to break-in the rings..
      • petejw
        • 2269
        • sydney australia
        #108
        another thing came to mind,
        what engine oil are you using?
        freshly honed cylinders and new rings need
        a mono grade oil to run the engine in,
        using normal oil can cause the cylinder bores to
        glaze causing the engine to smoke.
        pete
        new owner of
        08 gen2 hayabusa
        former owner
        zrx carbs
        18mm float height
        145 main jets
        38 pilots
        • stevestrom
          • 109
          • Abbotsford, BC
          #109
          Well I learn something new everyday! I just put the regular 20W50 stuff in after I put the engine back together. Since I have fuel in the oil from a rich running problem and I have to change the oil now anyway, what do you recommend?
          How soon could the cylinders glaze? The bike has been run maybe a total of 5 mins since it was put back together.
          Thanks for the help! It's nice to recieve since I am a total newbie at this rebuilding stuff.
          • petejw
            • 2269
            • sydney australia
            #110
            head down to ur local auto store,
            its a straight 30 weight oil,
            the same stuff used in lawnmowers etc,(small 4 stroke engines)
            ive also noticed valvoline sell oil specifically for running
            in engines again its a straight 30 weight oil,
            not sure what the difference would be between
            the 2 oils, (maybe even less detergents) if u cant get the oil specifically for running in engines
            then the straight 30 will be fine.
            with regards to glazing, hard to say
            the oil shouldve been put in
            straight away before the engine was started and the engine run in.
            start and stopping the engine, incorrect engine oil, doesnt take much,
            just read ur post again if its only 5 minutes running time u might be ok,
            make sure ur carbs are sweet, change the oil and take the bike out for a good
            hard run.
            heres a link i posted a little while ago about running in engines
            also dont forget to retorque head bolts and adj cam chain if uve
            fitted a new head gasket.
            who did the honing of the cylinders?
            pete
            new owner of
            08 gen2 hayabusa
            former owner
            zrx carbs
            18mm float height
            145 main jets
            38 pilots
            • stevestrom
              • 109
              • Abbotsford, BC
              #111
              There are still a few things that I have to button up on it before I can take it on the road, legally. Just finished resetting everything on the carbs again so they should be good now (fingers crossed). I'll get that oil and change it up.
              I did the honing of the cylinders myself. I was told that it should be done if the pistons are coming out of the cylinders. Did quite a bit of reading up on it before I did it though, made sure to not to take off too much material and left a good crosshatch. The whole bike had been sitting outside for at least 8 years without running, but it only has about 20,000 miles on it.
              • daveyg
                • Feb 2009
                • 411
                • Boise, ID
                #112
                So... Haven't heard much but interested in how it's all turned out...
                BARE BONES CHOPPERS: If it don't make it go faster, you don't need it!
                80 XS1100SG(cafe in progress *slowly)
                • stevestrom
                  • 109
                  • Abbotsford, BC
                  #113
                  Working on making it street legal at the moment so that I can take it out and run it in. It's getting close though. Need to paint and reassemble front brake calipers (rear is done). Signal and tail lights are currently in the mail. Still have to wait a bit so that I can afford the new speedo and shocks. Then the seat needs to be covered. I'll give pictures when the brakes and lights are installed, but can't give anymore info on riding until it's ready for the road. I am hoping to have it road ready within the next two months.
                  • roccet
                    • 102
                    • bend oregon
                    #114
                    i love it.. great color combination .. good looking bike!!
                    1978 E XS1100 purchased for =$600.00
                    crap load of time spent modifying it = Priceless
                    My bike has the XS motor but can't really call it XS11
                    (or at least it still looks like the XS motor)
                    it has about 50% of the frame left from the XS bike
                    • stevestrom
                      • 109
                      • Abbotsford, BC
                      #115
                      Well still working on getting the bike road worthy. Here are a couple of pictures of the bike now. I mounted a tach, installed the front signals and headlight wiring, bled the rear brake and made a bracket to attach the rear tail lights and plate.
                      I still have to put on new shocks (when they get here), put a cover on the seat, wire in the tail light and rebuild and mount the two front calipers and master cylinder.
                      So close but so far
                        #116
                        Very nice! What's your exhaust? What are you doing with your old shocks? Anything wrong with them?
                        • stevestrom
                          • 109
                          • Abbotsford, BC
                          #117
                          Thanks! I haven't had a good look at the shocks yet. They are pretty bouncy (lots of spring, very little shock) not even sure if they are rebuildable. I have nothing planned for them but they do not suit the style that I am going for. I am getting coil overs and didn't see the point in spending any money refurbishing the stockers.
                          Pretty sure the exhaust is a Mac. There are no markings on it, but it did come off an xs1100 special. I like the sound of it despite what I have read about the macs on this site.
                          • petejw
                            • 2269
                            • sydney australia
                            #118
                            not sure of the type of shocks u have, but if they have adjustable dampening,
                            try turning them up 1 or 2 notches and see how they go.
                            the bikes coming up a treat. :-)
                            pete
                            new owner of
                            08 gen2 hayabusa
                            former owner
                            zrx carbs
                            18mm float height
                            145 main jets
                            38 pilots
                              #119
                              Let me do some research and maybe if your shocks are for sale I may be interested....
                              • cywelchjr
                                XS-XJ Super Guru(Deceased)
                                • 4450
                                • Sacramento, CA
                                #120
                                Those look like XJ air shocks which are rebuildable and are air adjustable. I have a set of them on my 80G and very much like them. There is an article in the tech tips I believe that tells how to rebuild them. I'm not sure if I can tell but it looks like the air line might be missing. If this is the case, they would likely have no oil left in them and of course wouldn't do any damping. If he is willing to sell them and they are what I think they are, I would consider them a good upgrade. Be aware that you may need to clearance the eye on the right lower side a bit to get it to fit in on an XS, but it's not too hard to do, and you would have to either flip them around 180 or or remove the helmet lock to make room for the air line to go over the frame under the seat.
