Green Dayna's
From experience I can tell you the 3.0 Ohm green DynaCoils work great. Give a nice fat spark and do not stumble when getting up around redline.
Bypass the resistor with these. I use 8.8mm ACCEL stainless wires with them and never seem to have a lack of ignition power or any high-voltage arcing to the head as can be common with the stock coils with made-on wires and terminal ends.
HOWEVER, you may need to make a few small mounting angles since they do not directly bolt up.
