Tail Light/Grab Bar
  • davidsymons53
    • 197
    • Peterborough, Ontario
    Tail Light/Grab Bar
    Are the tail light assembly and the grab bar inter-changeable on the xs850sg and the xs1100sg?
    David
    1981 XS1100 Special
    Previous Bikes
    1999 Honda Goldwing Aspencade 1500
    1983 Honda Goldwing Aspencade 1100
    1982 Honda CB900c
    1984 Honda vt750 Shadow. My son's bike now.
    1984 Honda vt500 Shadow
    • 3193
    I personally do not know but I do know if you check this site you will find out if the parts are indeed interchangeable.
    • TomRodgers
      • Jun 2008
      • 492
      • La Porte Indiana
      FWIW.....i 'obtained' a grab bar/tail light assembly off an 850....
      Here is what i found.
      The upper shock bolts are the same width apart so should bolt up no problem... the issue is further back on the frame. Where the STOCK turn signals mount ( the flared out round part with the little tabs in the middle)
      the mounting tabs on the back of the grab bar do not slip over these...
      I myself am planning on grinding down the stock mounts for the turn signals so that the thing will fit...then gotta modify the seat pan to accomodate the bar..
      I bit of work, but i think it will be worth it.....since i havent found a decent 1100 special grab bar that i could test fit. We shall see.
      If i can get some photos of what im talking about, ill post them.
      '81H (my first XS ) "Grey Ghost"
      4:1 Jardine w/ headerwrap
      Windjammer(wiring issues)
      New paint/brakes to come!!
      '80G FrankenBike (parts bike)
      '80G to fix "BlackSunshine"
      Stock Pilots/125 mains
      Pod filters; 4:1 Kerker??
      SS Brake lines w/ new M/C's
      LED Brake Lite
      Needs paint....
