Transmission blues??
    Originally posted by Jim_NH
    Do any of you have any additional advice beyond the step-by-step instructions? Is this washer move safe, reliable and worth the risk?
    What parts/pieces/materials should I have in place BEFORE I flip the bike and open things up?
    Any other notes, warnings or cautions?
    Thanks again for the help--well worth keeping these bikes on the road.
    Nashua NH
    Welcome aboard! The washer swap is definitely worth it. It tightens things up in there for a more solid shift. The one thing I will suggest is that you DO NOT need to flip the bike. All the extra work it takes to flip it over just does not balance out IMO. You can do the whole thing on the side stand, but the Centerstand is even easier (keeps things level). The only down side is you get a little more dirty laying on the ground under the bike.
    • Jim_NH
      • Nov 2010
      • 4
      That's very useful advice, as I'd really rather not flip the bike if I can avoid it. Fortunately, when I bought the Midnight Special, it came with a spare 1100 transmission, so I'm going to "practice" on that one, while it's on my workbench, BEFORE touching the MS.
      Will I need any gaskets other than high-temp RTV?
      Nashua NH
      1980 1100 Midnight Special (2010-Present)
      1986 FJ1200 (2005-2008)
      1978 XS1100 (1978-1995)
      Honda CRF 230 (X3)
      Honda CB350
      Honda CR500
      Honda XR650
      Ossa 250 Pioneer
      Kawasaki 350 Big Horn
        Regular Black RTV is what I used on the first few that I did. Then, I discovered "The Right Stuff". It comes in a pressurized can, and works SO much easier. You cut the tip to the desired bead size, then just push the nozzle sideways to dispense. It's a little more $ than the tube stuff, but you don't have to be as worried about oil residue and you can torque down the parts right away instead of waiting an hour like the tube stuff requires.
        So, to answer your question, no gaskets are required. The hardest part is removing the old gaskets from the engine though. They can be a bear...
        • strom
          • 1577
          • Slovenia, EU
          #34
          I did get gaskets for mine... you can get a complete set at louis.de at about 70 euro. Thats for the whole engine minus the middle drive and the top vent cover. You even get valve oil seals and some other smallish stuff.
          Anyway, I think the engine looks a bit better with a gasket than some goo around the seams.
          I did use high temp silicone thingie (loctite number.... something. Ask if you really wanna know and I will check) where the two engine halves meet.
          So... you can use silicone, rtv or gaskets... matter of preference.
          • xs11lover
            • 1433
            • Montoursville Pa
            #35
            JIM, Congratulations on getting the Midnight. I did get to take it for a ride before he sold it to you. It ran very nice, and it sucks about 2nd. Hope you get what you need out of the xtra motor. It's only been setting about a year, in my garage all the time. The bike just came off the road when I got it. It only was running on three but there were no problems with the trani.
            79 XS11 Special (Lazarus)
            79 DT 100
            • trdriver71
              • 360
              • Edmonton Alberta
              #36
              I have been reading all of the post about the transmission fix since it looks like mine will need to be done too. Would like to find all the information I can before I do mine.
              '79 XS11SF
              • strom
                • 1577
                • Slovenia, EU
                #37
                Just do it
                Its all in the wrist... i mean tech tips..
                • somesuch
                  • Jun 2007
                  • 145
                  • San Jose CA
                  #38
                  Just remember that the ONLY engine gasket that you actually need out of that kit is the Head gasket. ALL the other ones can be replaced with RTV. RTV is actually a lot easier to remove if you ever have to go back in there too.
                  Ditto here....I use either Suziki 1207B or permatex import grey for exact reason of very easy cleanup if I ever have to do it again.
                  I have done the second gear swap in less than 1.5 hrs on the motor that RTV intead of gaskets.
                  If you hang the bike by the bars so that the oil pan is in you face it is much easier....
                  BTW, it IS the second gear problem....
                  --Nick
                  • somesuch
                    • Jun 2007
                    • 145
                    • San Jose CA
                    #39
                    ... Is this washer move safe, reliable and worth the risk?
                    Nashua NH
                    The washer swap is a time tested and is very safe/reliable and def. worth it. besides RTV, oil, Dremel and some stones for it, the only other thing you might need is another shift fork if yours is pretty bad,
                    --Nick
                    • somesuch
                      • Jun 2007
                      • 145
                      • San Jose CA
                      #40
                      The 10 min limit.... hence another post
                      I use a felt pen to paint the dogs/slots, then slide the gears on the shaft and bang them a bit against each other. The contact points are then easy to see and you can Dremel away to make sure all the dogs make contact at the same time and along their whole surface.....you need to rotate the gear so different dogs engage different slots......for me this is the most time-consuming part, but I like to get them perfect!
                      --Nick
                      • Jim_NH
                        • Nov 2010
                        • 4
                        #41
                        Thanks to All Involved
                        I just completed the 2nd gear repair, using the outstanding instructions available on this website, and the wise advice from other members of this forum (i.e. move the washer, use the Right Stuff, mark with a Sharpee, etc.).
                        I'll post some photos and lessons learned, once I download the pics from my camera.
                        Thanks to everyone who responded with advice and words of wisdom. The Midnight Special is fully functional and back on the road, where she belongs.
                        Nashua NH
                        Honda CRF 230 (X3)
                        Honda CB350
                        Honda CR500
                        Honda XR650
                        Ossa 250 Pioneer
                          #42
                          Glad to heat it went well and she will be back on the road again!!
                          • strom
                            • 1577
                            • Slovenia, EU
                            #43
                            Me too. Just did a test ride at 10 pm and we had 40cm of snow the next day
                            At least I know it works now...
                            • xs11lover
                              • 1433
                              • Montoursville Pa
                              #44
                              Hey Jim, here is another one for you to fix.
                              79 DT 100
                                #45
                                http://buffalo.craigslist.org/mcy/2179042620.html
                                If it "was red and rusty" it probably isn't a midnight special
