In the Freezer
  • Brad
    • 136
    • Regina, SK CANADA
    In the Freezer
    I decided to take off my carbs after work today and looks bad. All 4 carb mixture screws are broken and stuck. Number 4[IMG][/IMG]
    Number 3 [IMG][/IMG]
    Number 2[IMG][/IMG]
    Number 1[IMG][/IMG]
    They are in the freezer cause the wouldnt budge. Any thoughts on using a hand drill to drill them out with a 1/16 bit? Or should I use a drill press?
    Gotta get...[IMG][/IMG]
    back on the road for one of the last weekends to ride in the great white north.
    Some make 'em, most just make payments on 'em!
    1978 XS 1100E
    Vance & Hines Slip on Straight Shot Exhaust
    K & N Air filter
    Home built forward controls
    Vulcan Mustang seat
    A little chopped
    http://s812.photobucket.com/albums/zz42/Brad_099/
    • 8930
    Drilling them out should be a last resort. It looks as they are sticking thru enough to push/pry them out.
    • GARTHXS
      • Nov 2007
      • 1631
      • Seattle
      don't do it
      Put a little pb blaster in the tops and put the screws back in and freeze them overnight they should pop out easy. Its all in the levereage I use a mechanics pic that's tip is flattened so that you can apply preasure and a big box end wrench for a lever to press down on the pick.
      91 kwaka kz1000p
      Stock
      ( Insert clever quote here )
        Now I've never dealt with this problem, but it seems to me that a round object just a little smaller than the inside diameter of the carb throat and something to press it against the top might work on these tips like this.
        • Brad
          • 136
          • Regina, SK CANADA
          Cool, thanks for the help guys. I will try to get them out in the morning, if not, hand drill with a 1/16 bit it is. The bike ran when they were all plugged, would bogg out when I tried to pop the clutch. Also bogged out at high rpm, top speed was 175km. It also would not idle in warm temprature. Hopefully she runs.
          Last edited by Ken Talbot; 10-21-2010, 11:08 PM. Reason: changed to 1/16 drill from 5/16 - hope that's what you meant
          1978 XS 1100E
          K & N Air filter
          Vulcan Mustang seat
          A little chopped
            Highly recommend a drill press if you go that route.
            Many folks have resorted to drilling them out and the carb will tune still, its just maybe a little more finicky or a different start point or setting than without drilling.
            • old_chopper
              • Sep 2010
              • 120
              • Oklahoma
              I can't see the pics so I am guessing you are talking about the tips of the mixture screws being stuck. What does freezing the bodies do to help? The aluminum will shrink more than the brass and I would guess this would actually make them tighter.
              I have never tackled this problem before so I'm asking and sorry but I don't have any proven suggestions.
              US Army 1986-1991
              1979 1100 Special (on the road after 16 years!)
              1983 GS300L (wifes ride)
              1985 Super Glide
              2012 Super Glide
              • 81xsproject
                • 3185
                • Fortuna, CA
                Many folks have had great success using the freezer method on broken needles. Drilling them out should be the option right before you decide to through them in the garbage.
                '81 XS1100 SH
                Sep. 12th 2015
                RIP
                • Brad
                  • 136
                  • Regina, SK CANADA
                  Hey oldchopper. Is this your bike on youtube?
                  Cool bike.
                  1978 XS 1100E
                  K & N Air filter
                  Vulcan Mustang seat
                  A little chopped
                  • Brad
                    • 136
                    • Regina, SK CANADA
                    Didnt work
                    Well I tried, stuck the small screwdirver pick in my thumb . Took the carb to the shop today a drilled them out. I cant find any screws here in town, so I used the old ones and put the carbs back on anyway. It was a little hard to start and I asume its because the bowls were empty. After I got it going, same problem, It wont idle. Took it out for a spin and still has a slight studder wide open. Gonna try to play with the screws tomorrow.
                    1978 XS 1100E
                    K & N Air filter
                    Vulcan Mustang seat
                    A little chopped
                      Amy yamaha dealer should have them for a few bucks a piece, or get hold of georgefix on ebay to get some screws.
                      • lancelot455
                        • Sep 2010
                        • 174
                        • Regina,Saskatchewan,Canada
                        You should be able to get those from Reed Leisure Products.
                        82 XJ1100
                        Canada
                        2006 V-Star 1100 custom
                        • Brad
                          • 136
                          • Regina, SK CANADA
                          Thanks Mike, will check tomorrow. I only checked Thunder City, Alsport, and Dino.
                          1978 XS 1100E
                          K & N Air filter
                          Vulcan Mustang seat
                          A little chopped
                            • 8930
                            Those BS34-II Mikuni mixture screws are hard to find at a reasonable price. Anyone find a good source, please post it.
                            • lancelot455
                              • Sep 2010
                              • 174
                              Did you find those parts at Reed's?
                              82 XJ1100
                              Canada
