Hi all, I was wondering if someone might know where I might be able to pick up a colortune in Las Vegas this weekend? (Oct 22 to 25) Any ideas? I live in Canada and my friend will be in the Vegas this weekend.
Wher to get a Color tune?
Some make 'em, most just make payments on 'em!
1978 XS 1100E
Vance & Hines Slip on Straight Shot Exhaust
K & N Air filter
Home built forward controls
Vulcan Mustang seat
A little chopped
http://s812.photobucket.com/albums/zz42/Brad_099/Tags: None -
Best place is online. http://www.carbtune.co.uk/colortune.html or just watch ebay. 14mm is the one you want.Nathan
Theodore Roosevelt -
Yeah, I doubt you'll be able to find a store that sells them. Online is the way to go.1980 XS850SG - Sold
-H. FordComment
If you were closer, you could come over to my house and get one out of the garbage.'81 XS1100 SH
Sep. 12th 2015
RIPComment
Theodore RooseveltComment
You don't want it. After fighting with it for a while and quickly realizing why it didn't work for crap (design flaw IMHO) I started to attempt to modify it. Then I got the WBO2. Unless your needles are damaged and/or the holes have been smashed open, you should be able to set them all equally, with maybe an extra 1/4 turn out for the inner two, at 2.5-3.5 turns out and have a beautifully idling motor (with a decent sync of course). I won't say too much more about how I feel about the CT because folks always get all defensive about it. I think there are better ways to spend $60, though.'81 XS1100 SH
Sep. 12th 2015
RIPComment
The thing is, there is a HUGE difference between 2.5 and 3.5 turns on the screws. As little as 1/32 of a turn makes a difference.1980 XS850SG - Sold
-H. FordComment
What problems did you have with it? I am truly curious, because I really like mine, but had to slog some dielectric grease over the window to keep it from arcing OUTSIDE the combustion chamber. Once I did that, it works great!
The thing is, there is a HUGE difference between 2.5 and 3.5 turns on the screws. As little as 1/32 of a turn makes a difference.. Turned the screws back into somewhere around 2.5 and put it around 13. From what I remember, on my bike, 2.5-3.5 was about low 13's to mid 12's all of which the bike seemed to idle okay with. When I through a new set of cleaned carbs on the bike to test fire for the first time I always set them to 2.75 and have never had a set with genuine Miki parts inside not fire right off on the first few cranks and idle smoothly down to around 800 rpm. But, like I said most others love it. I don't see the need to spend all that time on the idle circuit.
'81 XS1100 SH
Sep. 12th 2015
RIPComment
