Source of speedometer housing gasket
  • clcorbin
    • Jan 2010
    • 495
    • Albuquerque, NM
    Folks,
    I had to remove my speedo today to grease up the input shaft and to replace burned out bulbs. Needless to say, after 31 years, the gasket/damper that sits between the meter and the housing/mount is completely toast. I've checked bike bandit and they don't have this gasket.
    Any other sources for this thing? Or am I stuck with trying to use RTV and glue the original one back together?
    Thanks!
    -- Clint
    • 8863
    I've replaced the gaskets on both the round and square type guages with weatherstripping from Home Depot. There is a round edge type available that just needs one part trimmed off, then just put the seam on the bottom with a dab of RTV. The type that I used was white, so I painted it black, it looks like new.
      I think TC wrote something up about using some wearherstripping to replace it. Do a search for it or maybe someone else knows where it OS
      • clcorbin
        • Jan 2010
        • 495
        • Albuquerque, NM
        Thanks! I'll have to swing by Home Depot/Lowes and see what I can find.
        -- Clint
          • 8863
          IIRC, this is the type I used. I cut one round side off, but left the flat part on, which I stuck to the internal housing, then the external housing slips right over it exposing just the round edge.
          http://www.homedepot.com/Tools-Hardw...atalogId=10053
          • clcorbin
            • Jan 2010
            • 495
            • Albuquerque, NM
            Interesting. I don't think I would have even stopped to look at that style, but I definitely see how that would work with a bit of trimming. Thanks!
            -- Clint
              • 8863
              oops, edit.
              • SFSPECBIKER79
                • Jul 2008
                • 403
                • NC
                iirc, this is the type i used. I cut one round side off, but left the flat part on, which i stuck to the internal housing, then the external housing slips right over it exposing just the round edge.
                http://www.homedepot.com/tools-hardw...atalogid=10053
                you got a picture of the finished product mounted?
                79 xs 1100 spec & 80 xs 1100 g
                  • 8054
                  New ones are available from Yamaha. PN 3H3-83513-00-00 List price is $21.55 each. It's called a damper.
                  I found them for >$30 at Yamaha Sportscenter.
                    • 8863
                    • 79XS11F
                      • Jul 2006
                      • 3563
                      • Ottawa, Ont. Canada
                      The round ones are easier to find then the square ones. They are very few and far between. E-bay sometimes but not often. At 20 some odd dollars a pop, it's often cheaper to buy a set of gages and salvage the damper out of them with care.
                      Rob
                      KEEP THE RUBBER SIDE DOWN
                      1978 XS1100E Modified
                      1978 XS500E
                      1979 XS1100F Restored
                      1981 Suzuki GS1100
                      1983 Suzuki GS750S Katana
                      1983 Honda CB900 Custom
                      • clcorbin
                        • Jan 2010
                        • 495
                        • Albuquerque, NM
                        I've been happy with the modified gasket. The stuff is cheap and you get enough for a couple dozen gauges. It doesn't look EXACTLY like the stock, but only a crazy person would notice (or care about) the difference.
                        -- Clint
