side cover mysteries need explaining
  • Adams77
    • 18
    • Statham, GA
    So.....according to this post http://www.xs11.com/forum/showthread.php?t=30433 I have a 79 XS1100F
    Now how do I (the novice) identify the correct left side cover? Any pics or special features to look for?
    • 8708
    You need a left side cover from a 78-79 Standard model XS1100. That is the only one that will fit correctly. Make sure the lock tab is in tact before you purchase one. They show up on ebay from time to time, or you might want to contact member Andreashweiss, he parts out XS11's.
      Here's what you're looking for if it's a '79...
      Check this against the right side cover you have...
      If your cover doesn't look exactly like these pics, somebody has swapped a later cover on. Note the 'slots' in the cover; these should be the same on both sides. The '80 covers use slots on the right side, round holes on the left.
      If the right side cover isn't a '78-79 (and I don't think it is), then you have to decide whether to buy (and modify) a matching left, or to buy a set of 'correct' covers...
      Either way, expect to spend some time finding 'em, and don't expect them to be cheap.
      • Adams77
        • 18
        • Statham, GA
        This is exactly like the right cover I have. So I am looking for the 78- 79
        • Bullet
          • May 2007
          • 185
          • Alliston | Ontario | Canada
          I have a set of both left and right ( same colour too ) I can part with cheap.
          private message me if interested ..
          1980 SG - "Blue Balls"
          Complete Restoration - Finished June 21/2010
          - 1179 kit
          - 80/81 carbs 42.5/115 mains with XS pods
          - Mac 4 into 1 exhaust
          - Venture auto CCT
          - progressive fork springs - no air
          - Mike's progressive rear shocks
          - Galfer S.S. Brake Lines
          - XSDirect - Black Coils
          - 8 mm S.S. Core Plug Wires
          - T.C. fuse box
          - TKat fork brace
          - Geezer regulator
          - Battlax BT45 V-Rated tires
          - 5W40 - Rotella T6 Synth Engine Oil
          - rest of bike is "good old Yamaha"
          • Adams77
            • 18
            • Statham, GA
            private message sent
