Shock air pressure
  • robquintana
    • 8
    • Ocean Springs, Ms
    Shock air pressure
    I have an '82 XJ 1100 maxim. Does anyone know how much air pressure should be in the front and rear shocks? any info would be helpful. And where I might find a repair manuel for this bike?
    Thanks in advance,
    Rob
  • lancelot455
    • Sep 2010
    • 174
    • Regina,Saskatchewan,Canada
    If you go through the threads there is a member that has all the manuals for the bike to download. Repair manual owners manual and drive shaft manual. In the owners manual is a chart for setting air pressure and dampening.
    82 XJ1100
    Canada
    2006 V-Star 1100 custom
      His name is CatatonicBug. He has a link in his signature line to his personal website and he has the different manuals there.
        Not sure if he has a XJ manual but I think there might be one there.
        • lancelot455
          • Sep 2010
          • 174
          He does have the XJ manuals. That's where i got mine from.
          82 XJ1100
          Canada
          • cywelchjr
            XS-XJ Super Guru(Deceased)
            • 4450
            • Sacramento, CA
            The pressure in the forks and shocks is based on personally preference. I have an XS, but I have XJ shocks on the back and the 80 has air forks. I run 16 psi in the front with 15w fork oil (silkolene) and 44 psi in the rear with the dampers set on 4. But then I'm a big guy and have a full dresser setup, so what works for me very likely won't work for you. Adjust the pressure very carefully using a hand pump, and move the pressure up and down a little till your happy with the ride. It took me a while to dial in to the pressures that work for me.
