And so it begins ... Yet Another bike building project
    • 8962
    That sucks, the Specials do have an petcock "off" position. Don't rely on that octy.
      And after being all hopped up on gas fumes you really just never feel right the rest of the day either...
      • 79XS11F
        • 3563
        • Ottawa, Ont. Canada
        No kidding. I can still smell it but no one else can so I guess its right in me.
        Rob
        KEEP THE RUBBER SIDE DOWN
        1978 XS1100E Modified
        1978 XS500E
        1979 XS1100F Restored
        1981 Suzuki GS1100
        1983 Suzuki GS750S Katana
        1983 Honda CB900 Custom
        • 79XS11F
          • 3563
          Is that a mechanical OFF in the petcock that is positive or can fuel still leak past the petcocks even in the off position?
          Rob
          1978 XS500E
          1981 Suzuki GS1100
            • 3193
            Fuel can leak even in the off position if your petcock rubber is worn out. Petcock rebuild kit are available though. From what I know the handle part of the petcock points to the word off when it is in the off position. I switched mine around as this always confused me.
              • 8962
              Off position should be with the levers pointing forward.
              • 79XS11F
                • 3563
                Meaning the lever's arm is over the work OFF. Just like on the standard model?
                Rob
                1978 XS500E
                1981 Suzuki GS1100
                  Is the "octopus valve" not functioning, or was it removed? You must have left the fuel cocks in the "on" position.
                    • 8962
                    Standard model petcock has no off position, unless of course you modify it.
                      Yes Rob, whatever word the handle is covering is the position of the petcock.
                      Special model petcocks do not operate on vacuum like the standards. I did a write up of the procedure to rebuild a little while back. Prime of course will have the same effect as ON only no mercy from the octopus if it is still in place and functioning.
                      • 79XS11F
                        • 3563
                        LOL Yes I know the standard has no off position but the lever is over the word for the function you want on the standard.
                        Rob
                        1978 XS500E
                        1981 Suzuki GS1100
                        • 79XS11F
                          • 3563
                          Octi is still there and I was sure it was working because there had been no leaks what so ever until last night. However, Like I was saying, I did correct the kinked fuel hoses. I must conclude that the kinks were limiting fuel flow.
                          Yes I did leave the petcocks in the on position but did so thinking the octi was working. Won't do that again and I will have to get into the habit of doing that because it's not necessary or as pointed out even avalable on the standard model.
                          Rob
                          1978 XS500E
                          1981 Suzuki GS1100
                            • 8962
                            Rob
                            Same for the Special.
