XJ Alternator Upgrade
    So I am going through looking at posts about upgrading to the XJ alternator and I am trying to figure out what all is needed for it to be done. So correct me if I am wrong but is it just the rotor/flywheel piece and then the stator that is mounted to the cover that is needed?
    Perhaps someone that has done this can chime in on some of the particulars of the switch.
    Thanks
  • Cobia
    • Jul 2007
    • 1587
    • Palm Beach County, Fl
    Nate,
    I think you're going to need the XJ ignition box as well, maybe even the regulator/rectifier but I'm not sure of that.
    I've been contemplating the same mod for my G but it hasn't been necessary yet. Bikerphil and I switched the coils from my J to the G before the Suches rally and they made a big difference. I'm restoring the J so I didn't need them at the time. I'll find another set for it later.
    1980G Standard, Restored
    Kerker 4 - 1
    850 Rear End Mod
    Automatic CCT
    1980GH Special, Restored
    '82 XJ1100 (Sold)
    • ManagerMike
      • Mar 2010
      • 445
      • S.E. Michigan
      As I've been able to gather from visiting these forums, the swap would gain a meager 4 ampere increase in electrical capaciy (22A to 26A).
      Hardly worth the effort unless your XS's charging system is in need of repair and needs to come apart in the first place. If your existing alternater is functioning as designed, you'll gain far more available capacity with a full LED conversion. JMHO
      '78 E "Stormbringer"
      • MindWebs
        • May 2009
        • 431
        • Baldwin, WI
        I'd say Mikes right.
        Led and HID and you'll have power left for whatever.
        i believe the only advantage other then the 2A gain is that it charges at full capasity at a lower RPM then the early 11's.
        i'm running a 79 with very minor electrical upgrades (LED dash lights) and have also the 750 final drive which drops my cruising rpm to 36-3700 at 58mph.
        my point is with a factory chraging system even at a lower cruising rpm i still have plenty of power with no extra accesories running.
        if you're wanting to tack items on, then you'll need the LED and HID upgrades.
        Good Luck.
          I already did the led dash Lights and am going to do the rest this winter. I am just kinda thinking out loud here, but its good to hear that its really not worth it.
          • brusky
            • Sep 2010
            • 8
            • Birmingham, AL
            Along the same lines, I'm considering adding driving lights to my XJ but I haven't figured out if I have enough wattage to do so. Does anyone have the numbers available off hand? So far everything electrical is stock.
            When you talk about doing the LED upgrade, are you just talking about swapping the bulbs with LED replacements or the entire light assembly?
            1982 XJ1100 Maxim
            • planedick
              • Mar 2005
              • 2068
              • Yorba Linda, California
              Formula
              Watts divided by volts equals amps. Amps times volts equals watts.
              Drilled airbox
              Tkat fork brace
              Hardly mufflers
              late model carbs
              Newer style fuses
              Oil pressure guage
              Custom security system
              Stainless braid brake lines
              • ManagerMike
                • Mar 2010
                • 445
                • S.E. Michigan
                I added 2 halogen 55w driving lights at first, before the led mod and the charging system could not keep up.
                I changed out all the lamps except the headlamp with led bulbs, including the dash and indicators, current draw for the leds is now a non issue. Now the only major draw is the headlamp, approx 5 amp on low, figure 7 amp on high, plus the TCI and coils figure a max load of 10 amps with high beam on leaving nominally 12 amps available for more acessories, with a 2 amp buffer for being on low beam 98% of the time.
                A 55 watt lamp draws about 5 amps (55w/12v=4.58 amp) times two and I should still have 2 amps to spare with the high beam on if I decide to restore the driving lights Or maybe I'll go with a killer stereo instead
                  You can change over to LED either way. The more difficult way would be to change out the light plug and then you can get little LED boards (or premade light assemblies) with anywhere between 2 and 36 LEDs on it that you can fit into the stock light housing. Or you can buy the LED replacement bulbs for the 1157 or 1156 bulb that you need. The bulbs are easier but more expensive.
                  I am researching the HID headlight and do plan to install one sometime soon. I am going to be doing my tail and signal lights for sure this winter. I also plan at some point to hook up a set of HID driving lights at some point down the road.
                  • brusky
                    • Sep 2010
                    • 8
                    • Birmingham, AL
                    So the XJ1100 service manual says the AC Generator produces 14V, 26A at 5,000rpm. Using the formula above, would I be correct in saying I have 364 watts (14V x 26A = 364watts) of capacity in my bike? If so, I assume I start working my way back from there by subtracting all the items that draw power to determine my available capacity?
                    1982 XJ1100 Maxim
                    • ManagerMike
                      • Mar 2010
                      • 445
                      • S.E. Michigan
                      Dead on, just be sure to leave a bit of overhead to be safe, you don't want to be maxing out the alternator all the time, life expectancy will be reduced.
                      • Jerry
                        XS & TRUE XJ GURU
                        • 3023
                        • Elma, IA.
                        Jut a comment. The XJ is a brush-style alternator. Brushes are getting harder to find. You would also need the right-hand cover in addition to the alternator itself since the alternator is longer on the XJ. Unless you really need the couple extra amps, in the long run you may be beter off sticking with the brushless XS design.
                        Jerry Fields
                        '82 XJ 'Sojourn'
                        '06 Concours
                        My Galleries Page.
                        My Blog Page.
                        • TomRodgers
                          • Jun 2008
                          • 492
                          • La Porte Indiana
                          JMO..... Ditch all the standard electrical bulbs that you can..... upgrade your 'flasher' to accomodate the LED turn signals.... HID lighting (im in the process of doing that now....translation...as soon as i get enuf $$$$ to do what i want to do!!!)....
                          I replaced all the bulbs with LEDS in the indicator panel...LED turn signals, and the LED replacement brake bulbs..... No more headlight dimming at stop lights/ low revs.....
                          These mods will REALLY benifit those with 'dressers' with the additional lights and accessories such as a radio... On "Ghost", my Sony radio no longer cuts out at stop lights!!!!!
                          Oh...and they handle vibration better and last much longer too!!!
                          '81H (my first XS ) "Grey Ghost"
                          4:1 Jardine w/ headerwrap
                          Windjammer(wiring issues)
                          New paint/brakes to come!!
                          '80G FrankenBike (parts bike)
                          '80G to fix "BlackSunshine"
                          Stock Pilots/125 mains
                          Pod filters; 4:1 Kerker??
                          SS Brake lines w/ new M/C's
                          LED Brake Lite
                          Needs paint....
                            Originally posted by ManagerMike
                            ....just be sure to leave a bit of overhead to be safe, you don't want to be maxing out the alternator all the time, life expectancy will be reduced.
                            Don't forget, if you use all the capacity on lights, stereos, etc, you may not have enough left to charge the battery!
                              Hey Tom, as you do the HID you should do a little write up with pics, and part numbers. I am still looking at things and trying to figure out what to go with when I do it.
                              Basically all I want (at this point in my life) is a couple HID driving lights and headlights, and a couple waterproof cigarette lighter sockets for cellphone, god, or ipod plug ins.
