Steering shaft top nuts
  • gui_tarzan
    • Sep 2010
    • 69
    • Mid-Michigan
    Ok, do these go on like a regular nut? I have been trying for 15 minutes to get them loose.
    Jim...<><
    '78 XS1100E
    Previous bikes:
    Early 70s Honda 90 Enduro
    1998 Honda Shadow ACE
    2006 Honda VTX 1300R
    Dogs understand why people ride motorcycles
    Well, they are locked together like any other double nut setup, so you need to turn the top one only first. But otherwise, yes, they just turn like any other nut. Try spraying the crap out of those threads with some penetrating oil like PB Blaster or the like.
    • gui_tarzan
      • Sep 2010
      • 69
      • Mid-Michigan
      Yeah! Now we're talking! That PB is amazing stuff. Thanks!
      Jim...<><
      '78 XS1100E
      Previous bikes:
        • 3186
        I have found that a sharp rap with a hammer and punch in the usual direction on the top nut will get the jam nuts free of each other. Pb blaster or other will definetly help.
          Hi Gui,
          yeah, penetrating oil works wonders, eh?
          Us bodgers whack them loose with a hammer and chisel because we don't give a toot if they get marked up.
          Skilled mechanics use two spanner wrenches that you can get from real tool shops or from Drummond McCall.
          One spanner wrench will usually undo the nuts if you turn the top nut first but you need two of them for reassembly because
          you set the bearing preload with the bottom nut then you need to stop it from turning as you jam the top nut against it.
          Now is the time to drill & tap the steering head tube to add a grease nipple so you won't have to tear the fork down the next time the bearings need grease.
