Bearings
  • Edisto
    • Apr 2006
    • 60
    • Roanoke, Va
    Bearings
    Looks like I need to do a bearing job on my '79 Special. I have a XJ 1100 parts bike with 17k on the engine. Does anyone know if it is possible to put this engine on my XS?
    1979 XS1100 F
    1980 XS1100 Special--Frankenstein
    1982 XJ1100 Maxium x 2
    1980 Honda CB 900
    1981 Honda CB 900
    1981 Honda CB650x2
    2003 Honda 1300 VTX Retro-sold
    • 8962
    Yep, it'll work if you use the ignition pick up parts and the alternator and rotor from the XS engine.
    • cywelchjr
      XS-XJ Super Guru(Deceased)
      • 4450
      • Sacramento, CA
      Actually I understand you can even use the alternator parts as well, but that requires some wiring work, but then you get a hotter charging system too. I'm sure if you have all the parts for the ignition with the parts bike you could even port that stuff over, but I'm not sure it would be worth it, then again think about never having to do pickup wire fixes again.
      • Edisto
        • Apr 2006
        • 60
        • Roanoke, Va
        Nice! Thanks for the input guys. Kinda of a shame to sacrifice the XJ motor. I'll keep an eye on here and ebay for a used motor, just in case.
        1979 XS1100 F
        1980 Honda CB 900
        1981 Honda CB 900
        1981 Honda CB650x2
