stainless screws, frame painting
  • tommystinson
    • Aug 2003
    • 425
    • Albany, NY
    Does anyone have a contact for metric stainless steel socket head cap screws? A lot of mine are looking pretty skanky, and I'd like to replace them, as long as they aren't in areas that need high strength screws. (I.E. Carbs, cam cover, grab rail, etc.) Also, does anyone have any recommendations for frame painting, powdercoating, etc.? I've heard powdercoating is expensive. Also, I'd like to clean up the welds on the frame at the same time. It appears that Yamaha has learned a lot between the XS and the current deltabox frames. Option 1: Have frame welds built up with additional welds and then grind, or 2: Fill existing welds with fiberglass filler and sand. Any thoughts or opinions would be nice. Winter is coming, and I've been imagining a dark grey metallic on the frame... Thanks!
    2010 Kawasaki Z1000
    1979 SF: Millennium Falcon, until this Saturday
  • xssiveone
    • 766
    • Windsor,Ontario,Canada
    I've never dealt with these people myself, but I have heard that other's have with good results. I have a lot of industry near me and was able to source mine locally.
    McMaster
    Metric Specialties
    Totally Stainless
    Brian
    remembering the same thing!
      You might even want to check out your local real hardware store. Mine carries a wide assortment of hex head bolts in metric and stainless!!!
      • Jeff
        • Apr 2003
        • 263
        • Pocatello, Idaho
        Most hardware stores that stock a decent fastner supply carry both Metric and SAE Allen capscrews in the standard black..... but only the SAE in stainless.
        1978 XS1100E "Flashback"
        "If at first you don't succeed.... Get a bigger hammer."
        • Pat Kelly
          • 3046
          • Golden Valley, AZ
          I'm with you on the quality of the frame welds. Someday I plan to smooth mine out too. I've considered JB Weld as a filler and sanding smooth.
          Pat Kelly
          <p-lkelly@sbcglobal.net>
          1978 XS1100E (The Force)
          1980 XS1100LG (The Dark Side)
          1999 Suburban (The Ship)
          1994 Dodge Spirit (Son #1)
          1968 F100 (Valentine)
          • beechfront
            • 673
            • midwest
            painting
            the estimate i got for a clear coat was along the lines of $400. powder coating cost me just above $200.
              • 5062
              ebay usually has sets of screws for bid. (chrome? stainless?)
              • Springer
                • Aug 2003
                • 76
                • Richmond, Virginia
                I saw a set on ebay the other day for real cheap might be worth looking...
                Madness comes from within.
                78 XS 1100 E (at Birth) "Madness"
                79 XS1100 parts bike "hunk of junk"
                83 Sportster "Lunacy"
                72 Shovel "Dark Shovel"
                • Geezer
                  • May 2003
                  • 2985
                  • Willamina, Oregon 97229
                  I've bought from the guy that has the selling the stainless screws on eBay right now. He's a good guy to do bisness with and he's selling them cheaper than the hardware store. I suspect he buys them very large quantities.
                  Geezer
                  • dragxs11
                    • Jun 2003
                    • 519
                    • Reno, NV
                    Looks like you've got plenty of insight here Tom. I'm very happy with stainless. You can't put the old bolts back in after chroming stuff. If I every rip mine down again, I think powdercoat is the best way to go. If your gonna go to that much trouble, you might as well get it done right. Careful with the stainless. They will munch those aluminum threads if you crank on them.
                    1980sg-Stocker-- Sold
                    1980sg- Cruise Missile- Sold to RODS454
                    1990 ATK 604- Ditch Digger
                    2005 BMW K1200S- Killer Bee
                    2005 Suzuki GSX-R 1000- trackbike
                    • tommystinson
                      • Aug 2003
                      • 425
                      • Albany, NY
                      Thanks everybody. I'm getting all my projects planned out for winter...
                      2010 Kawasaki Z1000
                      • tony7914
                        • Jul 2003
                        • 76
                        • warsaw indiana
                        stainless cap screws
                        hey there!!
                        i replaced alot of the cap screws on my bike with stainless srews i got from http://www.fastenal.com/ they have a store close to me and there prices were not to bad.
                        hope this helps!
                        tony
                        • ARRON
                          • Apr 2003
                          • 28
                          • neripis new brunswick
                          you might not want to here this but the honda's have a lot of chrome bolts on them ,they are the same thread and some times same lenght.i have used them on my bike(like the carburators and side coves)
                          • tommystinson
                            • Aug 2003
                            • 425
                            • Albany, NY
                            I don't mind hearing about alternative parts ideas from any source, especially Honda. I'm actually a "non-practicing" but factory trained Acura mechanic. I had the opportunity to see an oval piston NR750 once. I once said that only God or Honda could build such a thing. (No accusations of blasphemy please, I am in the church choir...)
                            2010 Kawasaki Z1000
