Petcock O-ring
  • ruffrider
    • Mar 2008
    • 60
    • Stanwood, Washington
    Petcock O-ring
    Does anyone know off the top of thier head the O-ring size for the fuel petcock? Thanks, Ruffrider
    1979 XS 1100 SF(16k now, more to come)
    140 mains, 42.5 pilots, drilled airbox w/uni fliter
    MikesXS Coils- bypassed ballast resistor- new wires
    1975 GL1000 Gold Wing(81k-Old Faithful) and another 75 GL1000 project. MBS sickness for sure.
    Other Bikes Iv'e owned:
    1979 Kawasaki 750 LTD
    1980 Kawasaki 125 Enduro
    1975 Honda 400f
    1976 Honda CB360
    1968 Honda 160
    The Specials do not share petcocks with the standards. The one for the mating surface on the standard is diamond shaped, IIRC.
      Do you mean the one to mount it, or the one to seal where the valve goes into the housing?
      • Lamric
        XStremely XSive(Deceased)
        • 410
        • Kenley, Surrey, England
        The petcock to tank o-ring for the Standards is not a simple shape
        Brian
        XS1100 LG "Mr T", SG "ICBM" & FJ1200
        Check out the XS Part Number Finder
        Be not stingy in what costs nothing as courtesy, counsel and countenance.
          He has a special, and they are just a round o-ring. Not sure on the size though. You have to be sure you get one that's fuel resistant though.
          • Lamric
            • 410
            Ah, OK, the Specials have a simple ring, Yamaha still supply them, it'll be about $3.
            Hi Ruffrider: put your bike model in you forum signature to help people help you.
            Brian
              When I had a special tank I actually used RTV to seal the petcocks on, worked great! (probably wouldn\'t do it again though)
                I have a couple spares I can measure. The ones that come in the kits are not oval they come round.
                  Nate, RTV won't hold up to gasoline. Wile E. P.O., Soooper Genius! used it for the petcocks on Columbo instead of repairing/replacing them and putting in new o-rings.
                  Over time the gas seeped out around the petcocks and went under/through the paint. It stripped the paint off the bottom edge of the tank and made a mess that was really hard to clean up, seal and repaint.
                    That's why I wouldnt do it again. It was one I'd those I need this now and it will last long enough for now things.
                    • XS1100_OEM4ME
                      • Mar 2009
                      • 1619
                      • Fort Myers, Florida
                      O-ring
                      The "gaskets" between tank and petcock are not O-rings, they are oval's, some with dividers to insure screw/fuel seal. Just buy the right "gasket" for your bike/year After all, they are cheap/ adv. and gas leaking down on to a hot motor/exaust
                      1980 XS1100 Special
                      1990 V Max
                      1982 KZ750 LTD Twin
                      1974 CB750-Four
                      Past/pres Car's
                        Hi Ruffrider,
                        is that the seal between the petcock and the tank or the seal between the rotating and stationary parts of the petcock?
                        • ruffrider
                          • Mar 2008
                          • 60
                          The O-ring I'm talking about is the one behind the lever that shuts off the gas. I want to get some spares without having to buy the whole rebuild kit
                          1975 Honda 400f
                          1976 Honda CB360
                          1968 Honda 160
                            That's not an o-ring. It's a flat rubber valve. There is an o-ring that wraps around the lever itself though. If the flat rubber valve is in need of replacement, I would replace ALL the rubber bits in the rebuild kit.
                            • ruffrider
                              • Mar 2008
                              • 60
                              Yes, the O-ring around the lever is what my question is about. does anyone know the specs? Thanks
                              1975 Honda 400f
                              1976 Honda CB360
                              1968 Honda 160
