ignition problems
  • boediddly
    • Dec 2009
    • 50
    • columbus,oh
    ignition problems
    have any of you guys had any problems with the stator leads interfearing with the ignition opertion? especailly the one that the tach reads off of?
    • 8930
    If the plug from the alternator behind the fuse panel is corroded/melted, it will not charge the battery well and cause ignition problems. JAT
    • BigRed
      • Mar 2010
      • 265
      • Ottawa, Ontario, Canada
      I had a corroded plug... can't remember which one, but when I unplugged it, the bike would spark better, and the tach and dash lights were out. You just need to clean or replace the corroded plug.
      Good luck!
