Special Owners! Check Your Rotors!
    I thought I'd throw this out here, as this may be the reason why some Special owners have had trouble aligning their rotors/calipers. This shouldn't apply to standards, but may be something to look at if swapping rotors around, particularly between models. I mentioned this in another post, but though it might be good to call more attention to this.
    It's been stated here many times that all XS rotors will interchange and are dimensionally identical, with the only 'different' ones being the slotted versions. The parts fiche backs this up, as it only lists three kinds; 'standard' non-slotted rotors and the two left/right slotted ones. But this may not be true, as I have two rotors (out of ten) that are not identical to the others. The difference is in the 'dish' or 'offset'; the majority of mine measure as .750" from the mounting face to the outer friction surface, while the other two measure at .810", for a difference of .060". This can't be accounted for by wear, as all check within .015" of each other for disc thickness.
    Here's my thought; the Specials require you to align the rotor and caliper by moving the fork slider one way or the other in the axle clamp. But this can put your fork tubes out of parallel, introducing 'stiction' and wear problems. I think this is the main reason the Specials have bushings on the bottom of the fork tubes and the standards don't; the bushings help reduce friction and reduce wear. But what if the tolerance 'stack-up' requires a large movement of the fork tube to get alignment, maybe more than the engineers intended? I suspect this was an issue and the fix was these 'different' rotors (only used on the production line) to prevent problems on the new bikes. So if you have replaced or swapped around your rotors and had trouble with this, check for this. I'll note that one of these 'oddballs' was off a low-mile unmolested Special, and the other was on a standard that did show signs of having had bits replaced, so who knows on that one.
    Maybe someone could verify this on some other rotors...
    I feel as though I read something about this in some old posts once when I was going through reading posts about brakes. Don't remember specifics but it was something about dish differences.
      That was probably me Nate, but at the time I couldn't figure out why there would be different rotors. This is the only explanation that makes sense.
      The only reason I found this was as I was building my parts for my 4-piston caliper swap, I was just slipping the rotors on the wheel for 'test fits', using whichever rotor was at hand. All of a sudden my measurements changed and I couldn't understand why if all the rotors were the same... well, they're not...
        Perhaps one of mine?
        Hi Nate,
        way back, I posted about front XS650 & all XS11 brake rotors being interchangeable.
        I added a caveat that the two-piece rotors from pre '77 XS650s would NOT interchange because they were dished differently.
          ...way back, I posted about front XS650 & all XS11 brake rotors being interchangeable...
          The whole point of this post is the fact that not all XS11 rotors are identical/interchangable, contrary to 'accepted' wisdom. The two oddball ones I have are proof of that. While .060" may not seem like a lot (less than 1/16th of an inch and not something you'd readily see with a naked eye), when you're talking machined pieces it is. This is more than enough to cause rotor/caliper/caliper bracket misalignment on any model of XS if you've swapped rotors around.
          I doubt if these 'deeper' rotors are common; more than likely, you'll only find them on some Specials that may not have met the specified production line tolerances, but that's just a guess...
            Steve, that's a good point with the difference of the rotors throwing the fork alignment out. On my Special with it's original rotors, both rotors are not in the center of the fork bracket. I align my forks by removing the springs and fully compressing the forks and then tightening the pinch bolt.
            • EricHa
              • Mar 2009
              • 201
              • IL
              Sorry to dig up this old thread, but I have been having problems installing front calipers on my SF, and wondered if this issue was relevant. I rebuilt the caliper, and have the piston completely depressed. I'm using new pads, and I can't get the caliper bolted up with binding and locking down the rotor. I have the correct angled pads in each side ( I think ) I had previously removed the rotors to clean and paint this winter, so they may not be replaced on their original side. Could that be a problem, or could I have something else screwed up?
              1979 Yamaha XS1100SF (gone)
              Airbox w/K&N element
              Jardine 4 into 1
              145 mains, 45 pilots
              1996 Ducati 900SS CR
              1977 Kawasaki KZ900-A5
              1975 Honda CB550K
                Originally posted by EricHa
                ....I had previously removed the rotors to clean and paint this winter, so they may not be replaced on their original side. Could that be a problem, or could I have something else screwed up?
                Yes it could. The only way to accurately check these is to set them on a smooth flat surface ('outside' facing up) and see if they're the same. If the 'dish' isn't the same on both, you'll see it. If you do have one of these 'deeper' rotors, install it on the side where the axle pinch bolt is. Torque the axle bolt (but not the pinch bolt) and check to see if the rotors are 'centered' in the slots on the forks. It should be on the axle bolt side, it may not be on the pinch bolt side. You may have to push/pull the slider to get the rotor centered, then tighten the pinch bolt. That should allow the calipers to go on without dragging....
                Also make sure your speedo drive is aligned right and firmly against the fork.
                • EricHa
                  • Mar 2009
                  • 201
                  • IL
                  Thanks Steve! I will try this tonight. What a great forum.
                  Jardine 4 into 1
                  1975 Honda CB550K
                    - - - set them on a smooth flat surface ('outside' facing up) and see if they're the same. If the 'dish' isn't the same on both, you'll see it. - - -
                    Hi Steve,
                    WTF? I've been happily assuming that "rotors is rotors" and they were all the same.
                    (not the 2-part rotors from early XS650s, I know they have a different dish height.)
                    Is it a tolerance thing or are they deliberately made in different heights?
                      Fred, I've got two rotors in my 'spares' collection with that different dish. Like I said, unless you compare/check them, you'll never see the difference; they look identical. Both came off XS11s too...
                      I've learned to be a bit distrustful of the parts fiche, as I've found other parts they claim are the same but aren't, quite....
                      • tom clisham
                        • Sep 2010
                        • 627
                        • Northern Illinois
                        rotors marked with R
                        The rotors are stamped with an R for right & rear.
                        The left one has no stamp. I guess they are different.
                        Tom Clisham
                        Age is relative YOU WON"T GET OLD TIL YOU SELL THE BIKE
                        _____________________________________________
                        '78xs1100E ,all stock & original GONE TO WISCONSIN
                        '80 SG Vetter fairing,hard bags,trunk,fork brace,
                        stock headers with fishtail mufflers,black & beautiful GONE TO ARIZONA
                        79SF lowered,jardine 4/2 exhaust,pod filters,drilled rotors,fork brace, bar hopper
                        79SF 1 owner,8000 miles, restoring to completely original ( I hope) GONE TO FRANCE
                          Only the slotted ones are marked....
                            • 3193
                            My Lh has different offsets. I forget the number but the rear one is slightly different than the front ones. The Groove cut in them is also deeper on the rear than the front set.
                            • EricHa
                              • Mar 2009
                              • 201
                              • IL
                              I didn't make much progress on this tonight. Promised my 8 yr old daughter some vintage Batman episodes before bed. I did realize that I neglected the process detailed in the Clymer manual for SF's, page 194...
                              Torque axle nut to 76 ft lbs, pump forks several times, move right fork sideways until left hand disc is centered within caliper assy. Then tighten axle pinch bolt to 14.5 lb lbs.
                              Could that be my problem? Tweaking fork to align, slanted pads? Seems like a hodge-podge setup on an otherwise well engineered machine. (Awaiting Yamaha god thunder clap...) I had just tightened the axle nut and proceeded to install caliper, did no right fork tweaking.
                              Jardine 4 into 1
                              1975 Honda CB550K
