Hey guys, I could use a pic of the front master cylinder internals to rebuild it, as I have the rebuild kit already, I checked the search and couldnt find a decent pic or explanation. I pulled the piston out, the rubber stuff was all decomposed, as far as I could tell the spring goes in, then the rubber cover? then the piston with the rubber seal which I rolled over the lip according to the tech tips. So, I dont f up the whole thing a pic or good diagram would really help. I looked at the bikebandit but when I blow up the pic its all distorted,,,,,,,this is for the rebuild of a 78 standard fixer.....thanks, Mike in Sun Diego
Front master cylinder rebuild pics?
Mike, there is a tech tip somewhere or an FAQ on how to put the seal on the plunger, it shows it pretty clear. There is als a good diagram of it HERE
If I still had a spare laying around, I'd break it down, but alas I sold all of them off but the one on Banshee. Your a nice guy and all Mike, but I don't like you enough to tear it open and bleed the system back out.
78 XS750 -
kind of helps
Thanks DXSGER,,,,,the pic sort of helps, I used the tech tip to put the seal back on but it doesnt show all the other seals and spring assembly. THe spring is big on one end and small on the other,,,,the original one was the same diameter, a dilemma, and the other rubber seals I am clueless to assembly since the originals were in pieces. So far I have the steel shaft with rubber seal on correctly but am not sure on the spring and other rubber pieces.....mike
1982 xj1100 maxim
1981 venture bagger
1999 Kawi Nomad 1500 greenie
1959 wifeComment
Mike, the correct order starting from the inside out is:
1. Spring. The large end goes in first, the small end should have a 'cap' on it that goes against the..
2: Inner seal. The 'cupped' side goes towards the spring.
3. Flat washer.
4. Piston with seal.
5. Plastic 'cushion' washer
6. Snap ring piston retainer.
7. Outer boot seal
8. Boot retainer clipFast, Cheap, Reliable... Pick any two
Thanks Crazy Steve
Big thanks, Crazy Steve,,,that is the info needed to assemble correctly, now to get the fixer going with brakes. All is well in XS land....Mike in Sun Diegomike
1982 xj1100 maxim
1981 venture bagger
1959 wifeComment
Sorry, don't know what I was thinking...
Move the flat washer to after #5....Fast, Cheap, Reliable... Pick any two
not sure if ur aware or not,
but u need to give the master cylinder a bleed
before bleeding the calipers, this can be done on
or off the bike in a vice.pete
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
[url]http://www.youtube.com/watch?v=3pA8dwxmAVA&feature=mfu_in_order&list=UL[/url]Comment
Thanks Steve. Simple and concise.Mike, the correct order starting from the inside out is:
3. Flat washer.
7. Outer boot seal
David1981 XS1100 Special
Previous Bikes
1999 Honda Goldwing Aspencade 1500
1983 Honda Goldwing Aspencade 1100
1982 Honda CB900c
1984 Honda vt750 Shadow. My son's bike now.
1984 Honda vt500 ShadowComment
