Leaking gasoline from air cleaner housing!?!
  • wrench78
    • Aug 2010
    • 7
    • East Bay, Ca
    I have a '80 xs1100g that leaks gasoline from the air cleaner housing at low rpms. I think it is a carb problem, but I am not sure. Also, there is a hole at the bottom of the air cleaner housing, and I am not sure it is supposed to be uncapped. It looks like maybe it had a cap at one time.
    Sound slike your float needle valves are bad or have a bunch of crud in them. Your vacuum valves must be shutting the gas off when the engine is not running.
    As to the air box, there is supposed to be a little filter and a cap with a hole in it there.
      • 7761
      Don't ride the bike like that. You could have a fire. DAMHIK
        And chekc your oil level, it may also be running into the oil. This thins the oil out and it can ruin the bearings.
        • wrench78
          • Aug 2010
          • 7
          • East Bay, Ca
          Thanks
          Thanks for all the advise, got it running right and loving it.
