clutch plate recommendations
    Starter slip.
    Yes, they have reported that problem as well. The starter clutch is a simple 3 rod/shaft compression grab design, they slide down a slotted groove and are squeezed against the starter shaft. But with the full synth, they can't get a good grip onto the shaft, they just slip around it instead of being able to pinch it. So...hopefully you are seeing that the Full Synth is probably causing several of your problems, and an oil/type change is warranted!!
    • pgg
      • Jul 2003
      • 394
      I agree with Steve Linderman that basic proper clutch adjustment is crucial. Sadly, sooner or later the poor tired 25 year old clutch wont respond to adjusting, no matter what you do. You're then really left with no alternative but to try other options.
      • beechfront
        • 673
        • midwest
        Well....
        clutch did not need adjustment, and 20w50 dino juice didn't help either. looks like i have a new project.
        • Snow
          • Oct 2002
          • 1041
          • Tallahassee, FL
          Just to chime in to what everyone else was saying - yes, fully synthetic car oil can and most likey will give you clutch and/or starter clutch slippage.
          I ran Mobil1 15w40 (maybe 15w50, can't rememeber) for a few months and it worked great, then my starter wouldn't engage and my clutch started to slip a little.
          If you want to use Synthetic, get motorcycle synthetic oil like Golden Spectro or Castrol Motorcycle Synthetic or whatever other brand you like. The biggest problem in regards to synthetic oils in these bikes is that darn wet-clutch.
            • 5058
            Someone once said that the synthetics made for cars were required to include additives (zinc?) to help preserve emmission control devices. The additives cause a slippery coating on the parts you need friction for, like the clutch and the starter. Yes, it is too slippery.
            • scalded dog
              • 458
              Why is 20w50 better than 10w40 for our bikes. Later 'Dog
              • mitch
                • Oct 2002
                • 934
                20W50
                Cause our bike are old and tired like me, the 20/50 weight doesnt thin out as much when it gets hot, so it will tend not to bypass the rings,seals etc. In other words ya wont use as much oil. now that is just my opinion Dog, i have been wrong before HTH...............MITCH
                Doug Mitchell
                82 XJ1100 sold
                2007 Stratoliner 1900 sold
                • scalded dog
                  • 458
                  Thanks Mitch, I thought that might be why but wasn't sure. Later 'Dog
                  • Geezer
                    • May 2003
                    • 2985
                    • Willamina, Oregon 97229
                    In case some one is considering a Barnett clutch, don’t. I’ve installed a few of them including a set on one of my bikes. They don’t slip but quite often they don’t release either. I had to start the bike in gear with the rear brake and the clutch lever tight against the bars to break it free. Then it would still grind into second. I replaced it after only a few hundred miles and after I managed to bend a shift fork.
                    On the other hand a Veserah clutchs act like stock and some people say they slip less than stock but I’ve never ran one hard enough to find out.
                    Geezer
                    • beechfront
                      • 673
                      • midwest
                      geezer thanks a ton for the advice.
