Fuel Tee
    Fuel Tee
    Where can I get one? Fast. I need the one that joins the carburetors.
    Is one of these correct for my bike? Look at T3 and T4. XS1100SG
    Thank you!
    FUEL TEE
    You want the T4 one; the T3 is the vent nipple (if the parts fiche is right)....
    Look up parts 72 and 77.
      Steve,
      The parts fiche at the YAMAHA site is what I'm using. Item #15
      What reference for 72 & 77
      Thanx!
        Those numbers are off the UK fiche, and specifically for a SF. I used that model as the 'T4' tee was listed for that. The 72 number comes up as also being used on the g, h, and j models (cross referenced and a pic of it; something the 'official' parts site lacks). The 77 number is noted as a 'nipple, vent' and only applies to the E, F, and SF, as the later carbs were vented internally. If you use the UK site and select the h model, part 15 will take you to the same detail page if you click on the part number.
        • yamahansolo
          • Aug 2007
          • 1113
          • jawga
          I got an extra set of carb bodies that still have the t's. They are from an 81 or 82??? You may have ride out and see... I work tonight but if you need the part give me a holler...
          79 xs11 standard
          8mm msd wires
          tkat fork brace...
          Fox shocks...
          mikes650 front fender
          led's gallore...
          renthal bars
          gold valve emulators
          vmax tensioner
          Rifle fairing
          • 81xsproject
            • 3185
            • Fortuna, CA
            marty, if your issue is a leaky T, they can be 'repaired' using yellow fuel-type teflon tape. It can be a bit tricky, but it does work in a pinch.
            '81 XS1100 SH
            Sep. 12th 2015
            RIP
              It's a long story, but mine is broken.
                crazy steve,
                I'm afraid I don't follow you on these UK site numbers. If you say T4 is correct for my SG, I'll go with that.
                Chris,
                This is the only contact I have for you. I need to ride down to Gainesville.
                  ...I'm afraid I don't follow you on these UK site numbers. If you say T4 is correct for my SG, I'll go with that...
                  Yamaha is remarkably inconsistant sometimes with their part #s...
                  The 'T-4' tee is listed as fitting the E, F, and SF bikes, which it does. But the OEM part # listed at their site is only correct for a E; the F and SF models each have different part #s listed on both parts sites for whatever reason. The numbers are close, with the only change being the first three characters; 2H7 for the E, 1J7 for the F, and 3H7 for the SF. But if you go to either the UK site or the Yammy site and look up the 'T' for any of the later models, you'll get one number; the same # as the SF. If you're on the UK site, if you click on the part #, it takes you to another page that shows interchange if any (in this case, the SF number is common to the G, SG, LG, etc, up to the J). The UK site even has a pic in this case. Seeing how the '78-79 carbs are identical to each other, that means the fuel tees are all the same for all years, in spite of part #s.
                  Yeah, it's confusing....
                    I didnt even know you could still buy those T's still, good to know!
                      You can't. Only aftermarket is available.
                      • yamahansolo
                        • Aug 2007
                        • 1113
                        • jawga
                        In that case i will sell it to you for 1 million dollars !!! muhaahahaha (dr. Evil laugh)
                        79 xs11 standard
                        8mm msd wires
                        tkat fork brace...
                        Fox shocks...
                        led's gallore...
                        renthal bars
                        vmax tensioner
                        Rifle fairing
                        • yamahansolo
                          • Aug 2007
                          • 1113
                          • jawga
                          Sorry droid was acting up... trying to post a pic
                          79 xs11 standard
                          8mm msd wires
                          tkat fork brace...
                          Fox shocks...
                          led's gallore...
                          renthal bars
                          vmax tensioner
                          Rifle fairing
                          • yamahansolo
                            • Aug 2007
                            • 1113
                            • jawga
                            Marty i sent a pm last night did you get or are u out of conus?
                            79 xs11 standard
                            8mm msd wires
                            tkat fork brace...
                            Fox shocks...
                            led's gallore...
                            renthal bars
                            vmax tensioner
                            Rifle fairing
                              Chris,
                              Are those carbs from a '78-'79. I don't have mine to compare, but those look like they might be the shorter version. Look at T3 & T4 in the 1st post.
