How do you clean a molex connector?
    I've gone through a lot of the connectors on my bike and replaced a couple, and kinda cleaned a few, but I was wondering if there was any chemical solution that you have used to clean the "patina" off the connector pins in the Molex connectors. They all seem to get a white film of corrosion, and it seems to brush off the pins fairly easliy with a metal toothbrush, but the female connectors are a bit more difficult to clean.
    I tried a fuzzy pipecleaner and some carb cleaner, but I'm not sure that did a very good job. Then I thought of using a product called "Tarn-X", designed for cleaning silver kitchenware. It says not to use on aluminum, but I would imagine that is because it won't leave a shiny finish like it will on Silver.
    Have you guys had any luck with any other corrosion removal products/tools?
    You should use electrical contact cleaner. There are varieties available at your local auto parts store or at Radio Shack. Specialty products are available. Just GOOGLE it. The right stuff will wash that corrosion right out.
    • Bullet
      • May 2007
      • 185
      • Alliston | Ontario | Canada
      got a ultrasonic cleaner ?
      When I putting together my bike, I cleaned all my harness connectors and plugs using my ultrasonic filled with about half water, then clamped a 1 quart ice cream tub to the edge of the ultrasonic with vice grips partially submerged in the water.
      Sprayed some brake cleaner ( couple cans ) into the ice cream tub.
      Turned on ultrasonic ( waves transfer to the brake cleaner that was in the tub )
      Dip in connectors( 3-4 at a time ) for about 10 minutes in the tub of brake cleaner, they came out looking new, connectors clean as a whistle, all corrosion gone .. connectors are white again.
      1980 SG - "Blue Balls"
      Complete Restoration - Finished June 21/2010
      - 1179 kit
      - 80/81 carbs 42.5/115 mains with XS pods
      - Mac 4 into 1 exhaust
      - Venture auto CCT
      - progressive fork springs - no air
      - Mike's progressive rear shocks
      - Galfer S.S. Brake Lines
      - XSDirect - Black Coils
      - 8 mm S.S. Core Plug Wires
      - T.C. fuse box
      - TKat fork brace
      - Geezer regulator
      - Battlax BT45 V-Rated tires
      - 5W40 - Rotella T6 Synth Engine Oil
      - rest of bike is "good old Yamaha"
        Cool! I had used electrical contact cleaner in the past, but all it really did was de-grease. By the name of that stuff in the picture, I would imagine it takes the oxidation away? Does it require any kind of scrubbing, or does it just dissolve the corrosion away?
          DeoxIT
          I have not used that particular product, but I expect it is similar to what I use on the job. If that is the case, yes it will wash away contaminants and corrosion without any scrubbing.
          • MrOzz
            • Aug 2008
            • 782
            • Massachusetts
            CatatonicBug,
            I use the same product. Works great. I do use a old tooth brush and give the connectors a quick couple of passes after I spay it on.
            1980 XS 1100SG
            Dyna 3 Ohm Hi Output Coils
            Pod Filters
            DynoJet Kit
            T.C.'s Fuse Block
            V-Max Auto CCT
              Well, I went to Radio Shack and got 2 of the little 2-bottle kits. That stuff is expensive! I'll give it a shot, and hopefully, get some amperage back.
              • tantor
                • Aug 2010
                • 43
                • North Vancouver B.C.
                You can also get a tool, from a real electronics supply store, which will scrape a molex connector (both male & female side). I think that Napa had them too! I'll have to see if I still have an Ultra-Pro catalogue kicking around...
                1982 XJ1100
                • CaptonZap
                  • Jun 2010
                  • 1748
                  • Denver
                  Before you reassemble them, go to a parts store and get a tube of silicon grease, like the stuff that Ford puts in all their connectors, and put it in all yours. Then you won't have to do this ever again. CZ
                    I will have to look for that. I was hoping something like that existed!
                    Well, that's the point of the 2nd can in that 2-can kit of Deoxit. It's the protector spray. Of course, I also have a can of dielectric grease that I use quite often too.
                    • DenyP
                      • 599
                      • Staples, Minnesota 56479
                      You can find electrical contact cleaner at many hardware stores and auto parts dealers. LPS makes a great product and is widely available.
                      Deny
                        Deny
                        Yeah, but most contact cleaners are only a de-greaser. They don't do anything for corrosion. That's the selling point for the De-Oxit stuff, that it bubbles and eats away the corrosion. If there's another product that does the same thing, I'd like to know about it.
                          A quick GOOGLE turned up a bunch of them. Aerospace products work best, but they are extremely pricey.
                            Well, neither of those two examples get rid of corrosion. They only get contaminants like dirt and grease.
                              I got tired of looking. I use the airplane stuff, and it does the job you seek to do. I expect the DeOXIT will do a fine job.
