Carb Bowl Screw Size
  • digitalsam
    • Aug 2008
    • 208
    • Carlsbad, NM
    I am in need of four carburetor bowl screws. I bought a set of carbs off of ebay and failed to notice that the screws on the bottom of the bowls were not included. Does anyone have some that they are not too proud of $$$?
    If not, does anyone know the size/pitch etc of the bolts? Do they need to be brass? If not, I can probably pick a replacement bolt up at the local Nuts-R-Us, if I have the size/pitch of the originals.
    Sam Christensen
    The Chronicles of my Rebuild http://xs1100rebuild.blogspot.com
    If you are leading and no one is following, maybe your just taking a walk.
    Currently bikeless. Sold my 1980 XS1100 Special
  • CatatonicBug
    • 6117
    • Clinton, UT
    I'm sure that if you take the carbs into Home Depot or a similar establishment, you'll be able to quickly locate the correct allen-head screw.
    • clcorbin
      • Jan 2010
      • 495
      • Albuquerque, NM
      They are M5x1.0 x 14 long. A fairly standard screw, but if your Home Depot is like mine, good luck finding any metric screws in that size. Supposedly they have them, but I've never seen any screws in the bin...
      -- Clint
      • Bullet
        • May 2007
        • 185
        • Alliston | Ontario | Canada
        They are M5 x .80 x 14mm
        1980 SG - "Blue Balls"
        Complete Restoration - Finished June 21/2010
        - 1179 kit
        - 80/81 carbs 42.5/115 mains with XS pods
        - Mac 4 into 1 exhaust
        - Venture auto CCT
        - progressive fork springs - no air
        - Mike's progressive rear shocks
        - Galfer S.S. Brake Lines
        - XSDirect - Black Coils
        - 8 mm S.S. Core Plug Wires
        - T.C. fuse box
        - TKat fork brace
        - Geezer regulator
        - Battlax BT45 V-Rated tires
        - 5W40 - Rotella T6 Synth Engine Oil
        - rest of bike is "good old Yamaha"
          • 7863
          METRIC 18-8 SS SOCKET HEAD CAP SCREW, M5 THREAD, 14MM LENGTH, 0.8MM PITCH
          METRIC 18-8 SS SOCKET HEAD CAP SCREW, M5 THREAD, 10MM LENGTH, 0.8MM PITCH
          I bought them like this from McMaster-Carr. This for the bowls and top caps. They were delivered next day.
            I think he is asking about the drain plug. Not the screws that hold the bowl to the body. I only have the 81 style with the side inlet drains.
            • MrOzz
              • Aug 2008
              • 782
              • Massachusetts
              If you have a ACE True Value hardware store I would check them first before Home Depot.
              I have had better luck finding screws there. Also True Value has stainless and chrome bolts, nuts.
              JAT
              Ozz
              1980 XS 1100SG
              Dyna 3 Ohm Hi Output Coils
              Pod Filters
              DynoJet Kit
              T.C.'s Fuse Block
              V-Max Auto CCT
              • CatatonicBug
                • 6117
                • Clinton, UT
                I think you're right... In that case the info is as follows:
                M8 x 1.25, approx 6mm long, 10mm head size, brass
                I don't thing they have to be brass though. They do have a washer on them too.
                  • 1348
                  Copper vs Fiber Washers
                  And my preference for the washer isn't copper nor plastic either. Sure...they may allow for extended and repeated "on/off" but I found that in order to get them to SEAL the torque was higher than I was comfortable with.
                  I go to an auto parts store to get Fiber washers suitable for use with gasoline. Plus I get an extra set just in case they tear. (What?? Me actually lose one? Nawh...That NEVER has happened.)
