Well it's good I have picked up my BDF Special from Big Daddy Funk as my head light and gauge lights are out once again. I have found the problem to be the stator once again. This is my 3rd stator in two riding seasons.
Is there something that could be causing this or is it just rotten luck. I am wondering if the diode in the wiring harness is failing and allowing current flow back towards the stator causing it to short out. Can this happen?
Each time my stator has failed it has only been the headlight and gauges that are affected never the tach. That is why I am suspecting the diode in the wiring harness that is between the stator and the head light relay. I haven't had the chance to test that diode yet.
I hate to burn up another stator any helpful input will be appreciated.
