81 H fuse panel
  • hamjam
    • 1003
    • Toronto ontario Canada
    81 H fuse panel
    can someone please tell me what the order of the fuses are in the fuse box , from front of bike to rear . is the ignition fuse first like all the other models < i understand that there were some changes in this year of bike.
    Checking voltage across the battery last night ,there was a 6 V drop when the ignition switch was turned on I pulled the fuses and it is the fuse closest to the front of the bike. what all is on that circuit? It seems something is shorting somewhere
    TIA
    Seamus Ó hUrmholtaigh
    Niimi Moozhwaagan
    NOTICE: No trees were destroyed in the sending of this message. We do concede, however, that a significant number of electrons may have been inconvenienced.
    Any connection between your reality and mine is purely coincidental.
    Member of "FOXS-11" (Former Owner of XS-11)
    and SOXS
    2008 Nomad "Deja Buick'
    Won't swear to the order, but by color of wire it goes liek this.
    Tan to R/W = Ignition
    Tan to Tan = Signals
    Tan to R/Y = Headlight
    Blue to BLue = Tail light
    • hamjam
      • 1003
      Thank you for the prompt reply ............but alas...... the PO in his infinite wisdom decided that buying one honkin big roll of RED insulated wire was better than a bunch of smaller more correct wires ....so ...I can only answer "is that the front red wire ,middle or rear red wire "
      so I need to know the order in which the fuses 'SHOULD" be placed on the panel , because that has changed as well
      Niimi Moozhwaagan
      and SOXS
        • 3192
        On my 81LH the fuses from front to back go
        10a Ignition
        20a Signal
        10a Head
        10a Tail
        Here is a pic of a 80 wiring diagram which I use. I can not seem to find one of a 81 anywhere. If it does not come thru big enough you can PM me your email addy and I can send it in a bigger format. Hope this helps.
        • rpgoerlich
          • Dec 2007
          • 643
          • Katy, Tx
          80G and 81H wiring diagrams that I've seen are the same.
          Richard
          • hamjam
            • 1003
            thank you all this is the information I need
            now as soon as the rain stops I ll go see if I can get Phils bike going
            Niimi Moozhwaagan
            and SOXS
              Of course you realize the same PO could easily have put them in any order. Perhaps if you trace the red wire back you will find where he spliced it into the original wire of the colors indicated.
              • hamjam
                • 1003
                so true
                but with the wiring diagram I just printed things should be simpler
                Thanks
                Niimi Moozhwaagan
                and SOXS
                  Fuse block
                  Hi Jim,
                  The sun is out Maybe this would be the time to install the nice new Fuse block
                  Thanks everyone for such useful info.
                  I have tried Ccatatonic Bugs links but still do not find the Manual SUPPLEMENT for 1981. which gives some different values for some of the electrical tests.
                  • hamjam
                    • 1003
                    ok maybe I'll ...... ok I'll phone you
                    Niimi Moozhwaagan
                    and SOXS
                      It's on page 276 of the Clymers manual. However, '80 and '81 share the same diagram.
                        Thanks Bug
                        I'll try again.
                          As the sun sinks slowly in the west.......
                          Hamjam cam e over and we tried a number of checks for voltage.
                          A few hours into the program the battery is almost completley drained. We now suspect the new in April battery may not be doing it;s job.
                          After another charge i will try and start the bike.
                          Thanks HamJAm.
                            Thanks HamJAm.
                            Yeah it started after a few tries. And after a few minutes it ran without choke, smooth idle. 13.3volts ar 2500 rpm 14.2 Volts
                            To morrow night I will check again and see what if any charge is left.
                              To night I first checked for charge. 99% and 12.7 volts.
                              Fired on first try with choke and ran smooth. 13.1 volts but when i checked the % it was down to 75%
                              to be continued to morrow.
