accel coil kit 20-309
  • tony7914
    • Jul 2003
    • 76
    • warsaw indiana
    hey there!!
    i'm thinking of replacing my stock coils with the accel 20-309 kit, can anyone give me some pointers and info on how they perform on a stock 79 xs1100 special?? any help would be great!!
    you guys are great and thanks again for all the advice!!
  • pgg
    • Jul 2003
    • 394
    If accel are similar to dyna, then you'll get a good sharp crackle to your plugs, combustion and ignition system. Great for cold starts and good at high revs.
    • Snow
      • Oct 2002
      • 1041
      • Tallahassee, FL
      I got the accels, they work great - from several others I have heard the Dynas work great and are easier to mount. It's not rocket science either way, but sometimes its better to go with the more straighforward path.
      • johnstewart
        • Sep 2002
        • 167
        Ya, after having a scare after work with the XS11 not starting up right away (first time for that), I decided it was time. I went with the Accels because with the Dynas you have to get the plug wires, caps, etc, seperately:
        Hope to have them in a few days...
        79 XS1100SF
        • beechfront
          • 673
          • midwest
          coils
          i went into the local bike shop asking about ordering dyna coils. They guy there told me that i shouldn't bother replacing them if they're working.
          He said, "from over 20 years experience working on motorcycles - trust me. you're not going to see any performance increase from new coils. If it works don't fix it."
          I then asked him about cold weather starts, which was my concern - and he said it would make no difference there either.
          I think I am short some power at low rpms but I can live with that. But I would like to resolve the problem I had last week riding in the rain (lost a couple cylinders for a few minutes)
          anyway - i sure has hell don't have 20 years of experience, but from what I've read and heard - a hotter/colder spark will make a big difference in how an engine runs.
          • Snow
            • Oct 2002
            • 1041
            • Tallahassee, FL
            You mention losing cylinders in the rain - perhaps they were either 1&4 or 2&3 which might lead you to suspect coils..but..did you check you pickup wires? Also, is your gasket on that cover good? There are a bunch of us that have had the problem of washing our bikes and the bike not starting until it "dried out"
            • beechfront
              • 673
              • midwest
              well just guessing from the way it was running - felt like I lost one cylinder, then about a minute later another went out and that one would come and go at random. They both came back once the rain let up. I figure it was the plug wires not coils. I have been thinking about cutting into the coils to replace the wires per the fix listed on this site. But if I'm going to do that - I'll probalby just replace the coils while I'm at it.
              One concern I have is that higher performance coils may put more strain on other components.
              • johnstewart
                • Sep 2002
                • 167
                Re: coils
                Ya, that's kinda what I figured. But I know my coils are suspect (my 2-4 is actually my 1-3 from my parts bike 'cuz my original was way out of spec), as are the wires and caps, so I figure I might as well make sure all is good.
                Something is very amiss. She wouldn't start this morning - had to take the damn cage into work - and it's sooo nice out, too. I'll have to have another look at the pickup this weekend.
                79 XS1100SF
                • Snow
                  • Oct 2002
                  • 1041
                  • Tallahassee, FL
                  You may also try checking your plug caps - before I put my new coils on, I replaced my plug caps - at least 2 of them were very mangled.
                  • pgg
                    • Jul 2003
                    • 394
                    Of course don't expect an extra 10 h.p. and a 20 m.p.h speed increase with a set of dynacoils. The standard coils work fine - but the dynacoils work better. End of story.
                    • Geezer
                      • May 2003
                      • 2985
                      • Willamina, Oregon 97229
                      What would really be cool is a MSD ignition box or some other CDI setup. The ones for bikes are horribly overpriced and if you adapt the ones meant for cars, you will need 2 of them. I’ve seen CDI do wonders on cars but I’ve never tried a conversion on a bike.
                      There is a common myth that XS11’s have CDI stock but all it’s only an electronically switched Kettering ignition system that gives a weaker spark with increasing RPM.
                      Geezer
