Depending on how stock you want to keep the bike, there are a number of thigns past the engine that can interchange, truly the entire drive line including the swing arms IIRC. The rear brake system should be identical, but the wheels are not and switching them requires switching a spacer and rear brake caliper support bracket as well. On the front, the wheels are the same, rotors can interchange but IIRC, the standard did not have slotted rotors and the special did. They will swap but not look the same.
Many of the electrical components and ignition components are the same as well.
But like Phil stated, frame, wiring harness, side covers, seat, and forks and triple trees are not the same for sure. Other things are also different I am sure that I do not recall right off.
Hi Greybeard,
what they said. Lotsa stuff can be swapped but it will look different. Also, if you are swapping in the Special forks,
swap it 'trees and all. If you swap the Special fork tubes etc. into the Standard 'trees the front wheel gets moved forward which will give you scarily quick steering although it's a real low-cost fix if you are fitting a sidecar. You will also be stuck with the Special's Weird Harold front calipers.
The front wheel speedometer gear/housing is slotted to fit differently at the bottom of the forks and in the wheel hub. The speedo cable housing fits only its 'match-up' speedo gear/housing. The speedo gear/housing is not interchangeable from Special fork tube to Standard fork tube. IIRC, from when I tried to do this 5 years ago, and discovered it was a "no-go".
"Life is not a journey to the grave, with the intention of arriving safely in a pretty and well preserved body; but rather to skid on broadside, thoroughly used up, totally worn out and loudly proclaiming:
Nice looking bike. Do you still have your old tank? I've been looking at getting a 80' special tank for my bike.
Hi Duck,
sorry, not for sale.
It's a good bet that Andreas has a Special tank that you could buy. But why? The Standard tank holds an extra gallon of gas and the way the XS11 drinks gas you may need it.
And for what bike? Your profile says you haven't got one yet.
New to the site, haven't updated my profile for the bike info yet. I thought the specs on the 80' special showed a 25 liter tank. Maybe I was looking at the wrong info.
Hi Duck,
that 2 is a 1. Clymer's sez the US model Special has a 15 liter tank and the US model Standard has a 20 liter tank.
There's a European model XS11 that has a bigger than the US Standard tank and it may well be 25 liters.
