Gas tank advice
  • XS1100_OEM4ME
    • Mar 2009
    • 1619
    • Fort Myers, Florida
    Gas tank advice
    I am replacing my 1979 XS1100SF Special tank. The org. tank had been repaired by PO and has some rust and seeping from seems. I have a nice 79 special tank with "no" rust inside (one dent that I have fixed) The question to all who have been down this road with 30 year old tanks that look great, should I POR the inside just in case, or does no rust mean no leaks. Does the factory seal hold up or leak with age no matter how clean the tank
    1980 XS1100 Special
    1990 V Max
    1982 KZ750 LTD Twin
    1974 CB750-Four
    Past/pres Car's
    You can never go wrong by coating the inside of.the tank.
      • 8963
      Myself, I would never coat the inside of a tank unless absolutely necessary, JMHO. If the coating comes loose, then you've got problems. These tanks seem pretty solid and I've never had any problems with mine (knock). If it was leaking, I would probably try to solder it before coating. Again, JMHO
      • XS1100_OEM4ME
        • Mar 2009
        • 1619
        Thanks Phil, that was kinda my thinking, once you kream a tank if it leaks again (the one I am replacing was kreamed by a GI that used US military seal stuff, and now it seeps I think I will clean and install, if it leaks, I can always POR it later
        1980 XS1100 Special
        1990 V Max
        1982 KZ750 LTD Twin
        1974 CB750-Four
        Past/pres Car's
          I have coated plenty of tanks in my time and I have never had one come off.
          • XS1100_OEM4ME
            • Mar 2009
            • 1619
            Nate
            What kind do you use, I have POR US seal, I have heard it is the best but I haven't used it yet ($100.00), just got it thinking i might on this tank
            1980 XS1100 Special
            1990 V Max
            1982 KZ750 LTD Twin
            1974 CB750-Four
            Past/pres Car's
            • SFerinTEXAS
              • Jun 2006
              • 877
              I agree with Phil. When I see a bike advertised with a coated tank it's a minus in my eyes. Not a deal killer per-sea , just not a plus. If it is fairly rust free leave it alone.Just remember not to let them sit not full too long.
              In the fall and a cold front comes sweeping in I make a point off topping off my tanks even if I am only a little low. Rapid temp drops will make any air inside condense and cause moisture.
              79SF
              XJ11
              78E
              • SthrnSqrl
                • Jul 2010
                • 77
                • Andover, Ohio
                I used Red-Kote on my last tank job. I can honestly say that with it, make sure you don't get it anywhere you don't want sealed. I had to sand some of it off the outside of the tank. Once it set, nothing else was moving it.
                http://farm2.static.flickr.com/1278/...01bfdb21_b.jpg
                1978 XS11 Standard -- For Sale or Trade
                4 into 1 (brand?)
                Special Tank (really sucks for size)
                Special Side covers
                Winjammer 5 fairing with Vetter Hard cases
                1979 XS11 Special (has a new home elsewhere)
                1982 Yamaha XV920J Virago - My new daily rider.
                National Cycle Plexi-3
                Saddleman double bucket seat
                custom paint
                • mxmikie
                  • Aug 2008
                  • 482
                  • Bouse az
                  i take mine to the radiator shop and let the coat it
                  careful what you wish for.........you might get it
                  • SFerinTEXAS
                    • Jun 2006
                    • 877
                    Did some research on Red-Kote. Found only good things about it. If I EVER had to do it looks pretty good. Sticking with my original opinion But if I HAD to.............and only if.
                    79SF
                    XJ11
                    78E
                    • XS1100_OEM4ME
                      • Mar 2009
                      • 1619
                      I thought these tanks were sealed from the factory with a crimp filled with sealer You are saying "solder" I would think that would cause the OEM sealer to leak from heat
                      1980 XS1100 Special
                      1990 V Max
                      1982 KZ750 LTD Twin
                      1974 CB750-Four
                      Past/pres Car's
                        I have used several brands redcoat and lot are my favs. It's just all in the prep work. I always do it before I paint a tank. I clean it out a little then I bring the tank to a machine shop and have them hot tank the tank to get out all the rust and anything that might be on the metal. Then I coat the tank right after I get it back so the metal doesn't have time to develop surface rust.
                          • 8963
                          I've helped a buddy solder his XS tank about a year ago, it had several pin holes behind the petcock, not directly on the seam. We used a solder iron with the gas still in the tank, just tilted it. . It didn't really get super hot, so I'd say the sealer survived.
                          • XS1100_OEM4ME
                            • Mar 2009
                            • 1619
                            Thanks
                            Thanks Phil for clearing that up, I am going to try the tank as is, 30 year old sealer and all, if it leaks, ill fix, if not I RIDE
                            1980 XS1100 Special
                            1990 V Max
                            1982 KZ750 LTD Twin
                            1974 CB750-Four
                            Past/pres Car's
                              • 8963
                              Lon, I think you'll be fine if the tank looked pretty good inside. When I bought my Standard back in '89, the tank was pretty rusty inside. I cleaned it out half assed and just rode it, cleaning the carbs out several times until the rust went away. There is no rust in it now and it's still holding strong, knock again. Good idea, ride now, fix later if needed.
