Moving rear directionals to license bracket
  • malber
    • Sep 2006
    • 568
    • Belmont, NH
    On my '81 special I have a 78 licence bracket with the square box lens. Beside it are two unused mounts. I'd like to move the directionals there so I can use some oversized saddle bags that don't quite fit on the back of the seat because of the current position of the directionals. I found some lights that look like they have 90 degree mounts on Parts'n'more, but they have square lenses and I'd prefer to keep with the rounded style. Does anyone have any pics or suggestions on how to do this and where to look for the hardware?
    1981 XS1100SH
    My bike actually came with the rear signals mounted on the license plate. There is a tube with a bracket welded to it that mounts on the license plate bracket and then the square signals are held onto the tube with pinch bolts and the wires all run through the tube. Dont know if its a factory setup for bags or if its something really well done by a PO cause it looks factory. I am just trying to figure out how to change the square signals over to round.
      • 8962
      Made my own signal bracket for the licence plate location. Used some flat bar and made the 90 degree out of some angle iron.
      • ManagerMike
        • Mar 2010
        • 445
        • S.E. Michigan
        I moved my rear directionals to the tail lamp/licence plate mount some time ago to allow for bags on my 78. Sill have the 78 stock square lamps though.
        No special hardware was needed and the wiring existed...
        '78 E "Stormbringer"
        • malber
          • Sep 2006
          • 568
          • Belmont, NH
          Thanks Phil. Looks like that's pretty much a bolt on solution which would be ideal as I wouldn't have to buy any new parts and could pick up the hardware as the 'ware store.
          1981 XS1100SH
          • Mr. Schweer
            • Dec 2008
            • 152
            • Clovis, Ca
            I've yet to figure out why people cover, block-out or blur their license plates in pictures. Just seems silly.
            '96 Kawasaki ZX11, bought February 5, 2015
            '79 Kawasaki LTD 1000, bought Oct 19,2010.....sold Sept 12, 2013
            '81 XS11 Special, bought May 6, 2010.....sold Oct 19,2010
            '79 XS 11 Special, bought July 3rd, 2008
            '78 XS11 Standard, bought July 2, 2009.....sold Aug 25, 2011
              • 8962
              Duh, to hide the number.
              • CatatonicBug
                • 6117
                • Clinton, UT
                But why? You drive around the countryside with it visible. What difference does it make, and what danger can it put you in if someone see's it in a picture online?
                I've wondered the same thing...
                  • 8962
                  Bug, better safe than sorry. It really didn't take that long to do. I probably should have taken the plate off so the entire bracket setup was visable.
                  • XS1100 Newbie
                    • Jun 2009
                    • 1106
                    • Battle Ground, Washington
                    Besides, they got the number of that bike that was part of the bank robbery.
                    1980 XS1100LG Midnight
                    1991 Honda CBR1000F Hurricane
                    A cold beer and another one!
                      I think I'd cover mine if I thought about it ahead of time. But then, I still need to check into the statute of limitations in some states before I go back!! Hate to have some Dad at my door because of a picture I posted. (yes, that is my version of a joke).
                        • 8962
                        You'd be suprised at some of the reasons to cover/blur the plate on a photographed vehicle, just google search it.
                        • ManagerMike
                          • Mar 2010
                          • 445
                          • S.E. Michigan
                          Seeing it online is the clincher here, If a ten second precaution can potentially save years of aggravation and thousands of dollars fighting a case of identity theft, well, why not work with Murphy than against him?
                          Some computer guru in Pakistan (when he's not working as a tech support agent for Dell) could take the plate info and the ip address associated with it and garner enough data to open credit accounts in someone elses name......or FAR worse.
                          A little cya never hurts.
                            Here in Ohio anyway, most counties have a property search function on their auditors web page. With simply a name I can find out where they live, and in some cases, what was paid for the house.
                            As to the plate info, here is a nice little story I may have shared before. Some years ago my wife was applying to take the bar exam, which requires a very in depth background check. They have to be certain you were squeeky clean prior to learning how to bilk people out of their lifes savings. Anyway, we sold a car to someone by setting it out at my mothers house. Cheap old car, $500 was all. So my mother let them use our plate to take the car home and they were supposed to bring it back, which never happened. Soooo... this is in May and my wife was born in Jan and here in Ohio, the plates run from birthday to birthday. So I get a call the next January from the dufus who bought the car telling me he lost the title and needed another to finally register the car. Told me the engine blew right after he got it and he never titled it and now can't find it. Hmmmmm, says I, rather convenient the timing of the registration isn't it. So I tell him I knew what he was up to and I would not do it. Calls back a couple times and I agree to sell him the title for $30, since it would cost me to get it and for my time and efforts. He argued, and I said well I'll just report the car stolen and you can prove you bought it then. He agrees to the $30. Nowww, the REAL fun begins. Two days later the phone rings, and it is the local sherrif where this guy lives. Wants to talk to my wife. I ask what about and he tells me he suspects her of selling drugs with this guy. Turns out he is in jail on charges, they confiscated the car, and they have survellience of a lady selling drugs out of the car that appears to be his girlfriend. So after a discussion of how this was not my wife, he insist we turn the title over to him. Now I am skepticle that this is one of his friends calling, so the sherrif tells me he will be at my house tomorrow to get the title (which I had gotten already), I did not give him the address, he knew it. I make certain it IS the sherrif, and give him the title after I filled it all in as being sold to this guy cause I want the record to reflect they took the car from him and not us!! Recall that bar exam thing where they look to see if you wiped twice on every Sunday or not.
                            So all that to say, what if some similar persons copies your plate? After all, if you lose your plate you can write the number on a piece of cardboard till you get a new plate made. Yep, covering that plate seems alot simpler than dealing with all THAT crap!!
