Hello folks, I need new float needles and valves for my 79 standard, found a site and the valves and needles, but then it shows, 1.5 2.0 etc, can anyone tell me which ones I need to order. Thanks, Later 'Dog
float valves and needles
Tags: None
Mine are labeled 2.0. Dont know if thats that right number but thats why mine say! PO's are a wonderful thing!Nathan
Theodore Roosevelt -
Thanks Nate, your other jets are the same as mine, so 2.0, is probably right. The price is 28.95 per valve and neddle. Later 'DogComment
Wow! You can get a FULL carb kit for less than that!1980 XS850SG - Sold
-H. FordComment
HEy Dog,
Another option you can consider is an "upgrade" to the viton needle valves and seats. The needel valves and seats from an XV920 (Virago 920) will thread right into those carbs. Some say the needle sits a bit higher so the tang on the float needs to be bent down.
Suppose to last and seal better than the metal to metal seats and valves that are stock. JATLife is what happens while your planning everything else!
78 XS750Comment
Viton needles
+1 on the xv920 upgrade! I accidently left the petcocks on for 3 days and had NO leakage. If I had done that with my stock seats and needles I would have had a crankcase full of gas!
I also got the Mike's XS plastic floats at the same time and I know I don't have $28 in each carb for the mod. Wish I had done it sooner.
1979XS1100SF
K&N's and drilled airbox
Jardine 4in1
Dunlop Elite 3's
JBM slide diaphragms
142.5 main jets
45 pilot jets
T.C.'s fusebox & SOFA
750/850 FD mod.
XV 920 Needle Mod.
Venture Cam Chain TensionerComment
Toolmaker
Thanks for saying what I have always believed, I am gussing you are without the octy and I never have seen the metel needles be a fail safe for total fuel shut off
I think I will do the upgrade as a 2nd fail safe if my octy failes, thanks
1980 XS1100 Special
1990 V Max
1982 KZ750 LTD Twin
1974 CB750-Four
Past/pres Car's
1961 Catalina 389/1970 Torino GT 351/1967GTO 12to1 comp./ Roller cam/ T-10/ 456 gear/Tri-power/1967 GTO 400, 1969 Camaro, 1968 Z28, 2001 BMW M Roadster 0 to 60 in 4.5 sec. Jaguar XK8Comment
Thanks Folks, I should be able to get the gas to stop running soon, when it's parked. Just recently started having this problem, but with 90,000 on it, I should expect some problems. LOL. Later 'DogComment
