New XJ 11 owner
  • Vaughn
    • Aug 2010
    • 6
    • Parker, Pa
    New XJ 11 owner
    I bought a 82 XJ 11 Maxim last night with 40,000 miles on it. I will need to find an owners manual and maintenance and repair manual for it.
    I will be putting new tires on in a couple months. What are some good recommendations. That 130 sure is close to the drive shaft housing.
    It has a oil leak at the top front on the overhead cam. Will I have to put new gaskets on. I don't want to touch it without knowing what the torque specs are first. It has a Slipstreamer windshield on it with mounts incorporated into the mirror stems. I want to lower the handlebars some for comfort. Doesn't look like there is much room it will go. My last bike was a 79 Goldwing. Sat totally different. Seat height to handle bars was just right for me.
    Thanks,
    Vaughn
    Welcome! For the manuals, go to any post (use the search function above in the header) by Catatonic Bug; he has a link in his signature for a FREE download....
    I just hope you're not dial-up challenged!
      Welcome to the forum! You can get a service manual from the link in my signature. The valve cover gasket can be replaced with RTV, so no need to try to purchase the actual gasket. The tires are normally rather close to the swingarm, so no worry there. There are TONS of threads on this forum about what tire is the favorite, so do a search and plan on several days of reading!
      This is definitely the place for information about these classic bikes, so ask any questions you might have, and be sure to post some pictures so we can follow along with your progress!
      • Vaughn
        • Aug 2010
        • 6
        • Parker, Pa
        Thanks for the info, Vaughn
        • cruiser
          • Jul 2004
          • 393
          • Winona, Minnesota
          The XJ has adjustable handlebars to change horizontal and vertical positions. Once you've downloaded the manual, check page 2-23 for complete adjustment procedures.
          XJ1100 Ruby Red
          XS1100LH "Midnight"
          1972 MGB Roadster "sold"
          • dbeardslee
            • 4385
            • Maineville, OH
            Like Bug said, you can use RTV to seal it, but you only need about a 1/16" bead. Anything more than that and it's going to get a little messy. You want to apply the rtv to the head, not the valve cover - tends to get scraped off when you put the valve cover back on. Torque spec is 7.2 ft lbs, or 186.4 inch lbs (depending on your torque wrench) on the valve cover bolts.
            And, oh yeah - welcome to Ch11!
            • KA1J
              • 664
              • Groton, CT
              I'm glad to know only RTV is needed to seal the valve cover gasket, I'm going to check the Shims on the XJ11 this weekend and I forgot to add the Valve cover gasket to my order for carb parts. I have no RTV at the moment, is there a good brand to get that won't be a bugger next time I go to check shims in 5,000 miles?
              FWIW, I ordered the parts from Len "Chacal" at info@xj4ever.com at XJbikes, paying by paypal. The order was out the door within 20 minutes of my placing it. Talk about perfect shipping, couldn't ask for better service than immediate!
              • justme1100
                • Jul 2008
                • 243
                • Eagle, WI
                Check this out
                Lots of info on this site.http://www.ringler.us/xs1100/XJ1100ServiceManual.pdf
                Just ME and my 82 XJ 1100. Mac 4>1-2 1/2" open baffle shotgun, no octy, K&N pod filters, LED tail/brake light & directionals, 750 FD mod, Ear Cannon air horn, modified bars and dash. "Motorcyclists are all bound together by a brotherhood tie through their love of the sport, and what difference does it make what machine he rides as long as he belongs to the clan." Walter Davidson, Dec. 1920 edition of Harley-Davidson Enthusiast Magazine http://s851.photobucket.com/albums/ab78/justme1100/
                  KA1J........visit your local auto parts store and get a tube of high-temp gray silicone using a thin film on cleaned top of head. Remove and clean cam-end plugs and recesses and do the same there before re-installing valve cover.
                  • lancelot455
                    • Sep 2010
                    • 174
                    • Regina,Saskatchewan,Canada
                    Post some pics of the bike(We like pics). I'd like to see what it looks like with the slipstreamer on it. I just bought one for mine and won't be installing it till spring.
                    82 XJ1100
                    Canada
                    2006 V-Star 1100 custom
                    • Yahman
                      • Mar 2008
                      • 779
                      • Salem, OR
                      Here's mine when I still had the Slipstreamer on it.
                      Closeup of the mounts.
                      Sorry for the hijack.
                      Larry
                      82 XJ1100
                      80 XS1100G (Project bike)
                      64 Yamaha YA-6
                      77 Suzuki TS-185
                      • lancelot455
                        • Sep 2010
                        • 174
                        Larry
                        That's the same one i bought but the mounts are different. They screw into the mirror mounts then the mirrors screw onto the mounting adapter.
                        82 XJ1100
                        Canada
                        • KA1J
                          • 664
                          • Groton, CT
                          Motoman... Thank you.
                          • Cobia
                            • Jul 2007
                            • 1587
                            • Palm Beach County, Fl
                            For a more compact installation of the Slipstreamer on my XJ, I used the holes you see immediately below where Yahman installed his support brackets/clamps. You get access to the back of the handlebar uprights by taking the cable cover off. Then I basically bolted the cylinder with the stud directly to the handlebar uprights with a nut and washer under this cover. By the 'cylinder with the stud" I'm referring to the one used for the windshield posts/standoffs, and that serves to tighten the clamps to the round handlebars.
                            I have the 16" Slipstreamer, don't know if you have the 19" one, and this setup provided the correct angle (in line with the angle of the forks) for my installation.
                            I hope I didn't mangle this explanation too badly. I know a picture is worth a thousand words but my J is undergoing restoration and I hadn't taken a pic with this setup.
                            1980G Standard, Restored
                            Kerker 4 - 1
                            850 Rear End Mod
                            Automatic CCT
                            1980GH Special, Restored
                            '82 XJ1100 (Sold)
