hello all its been a while. well got the bike the other day and no headlight working. been trouble shooting it tonight and have found that it seems no power to connections just ordered a reseve lighting unit but i am having a feeling that is not right.it worked for a bit but then found i had a bad blub so changed it and nothing. i will keep running it down in the morning checking the switch but i am asking do u guy have some additonal ideas or have run into it.
headlight
Tags: None
FWIW you can eliminate the RLU altogether.Nathan
Theodore RooseveltComment
Hey Devilschild: As stated bypass the RLU - your headlight will just come on when you turn your key on. The bike will still start up fine. You really "need" a headlight to be seen by the cages. If you want to wait for winter to try to track this down you can always run a 3 way switch from a local hardware store ($8 for a 10 amp one) running off you auxillary power. At least you'll have a headlight - low, high beam & off. This is what I have done & will dig into if this winter when its parked - at least for now I'm ridin and this works fine. I did the relay bypass too. - Dan'81 XS1100 LH - Midnight Special - been lookin' a long time for this one.
1179 big bore kit, 80SG motor
Rebuilt head, valves
TC Bros Forward Controls (Brass Pegs)
Tkat Fork Brace
T.C. Spade Fuse Box
Dyna Coils & wires
Mikesxs shocks,controls,& bars (special)
ISO grips with stelleto ends
4 into 1 black Bassani exhaust
Bridgestone Spitfires
Tuned by Tinman905
& a will to keep it.Comment
My headlight went out the other night, took awhile but found a fuse was blown, not in the middle of the element, but where the element connects to the metal end, couldn't tell by just looking at it, take a short piece of wire and by pass the fuse, when the headlight should be on. Later 'DogComment
