kerker fitment
  • GARTHXS
    • 1631
    • Seattle
    kerker fitment
    So I got a used kerker and was looking for some tips on mounting
    91 kwaka kz1000p
    Stock
    ( Insert clever quote here )
    • 8794
    It will pretty much mount up like any other 4-1. There is a special hanger bracket that goes with it which uses the passenger footpeg bolt and the stock muffler hanger location....
    07 Triumph Tiger 1050
    • GARTHXS
      • 1631
      • Seattle
      No dice on the center stand then?
      91 kwaka kz1000p
      Stock
      • mxmikie
        • Aug 2008
        • 482
        • Bouse az
        i did not have to remove the center stand on mine the kerker fit fine
          • 8794
          The centerstand fits fine, no problems. I only install it to service the bike.
          • xs11lover
            • 1433
            • Montoursville Pa
            I was able to use the centerstand with both the Kerkers I've had.
            Getting the oilfilter out is fun, but it can be done without exhaust removal.
            If you have an oil cooler it's even more fun.
            Other than the stock exhaust, I like the Kerkers best. Good pick!
            79 XS11 Special (Lazarus)
            79 DT 100
            • GARTHXS
              • 1631
              • Seattle
              I like the bassani but it is a pita to do oil changes I have to fish out the filter with my finger and I can't use the center stand except for maintenance
              91 kwaka kz1000p
              Stock
              • 65oldsboy
                • Jun 2008
                • 201
                • Aberdeen, MD
                I've only tried to change the oil once with the Kerker. I could not get it out without removing the pipes. After I got it all buttoned back up, I wondered if I could get the filter out of the dog bowl and just remove the filter without removing the whole bowl. Is that how you did it?
                It actually was a good thing that I did pull the exhaust. I found that the PO decided because the exhaust gaskets did not fit in with the Kerker and stock exhaust studs, that they were not necessary. I hope he didn't run it that way for too long. Longer studs and new gaskets were the next parts purchased.
                79 XS1100 SF - name TBD - possibly "Divorce Maker" Kerker 4 into 1, K&N filter in stock air box
                79 XS1100 SF - parts (for now) - "Divorce Maker II"
                79 XS1100 SF "The one that got away" sold in 1993.
                • GARTHXS
                  • 1631
                  • Seattle
                  With the pipes I have now I am able to drop the the cup and pull the filter a very messy job
                  91 kwaka kz1000p
                  Stock
