FJR1300 Rear Wheel?
  • Hideki
    • 85
    • West Hills, CA
    FJR1300 Rear Wheel?
    I've always wanted a more modern wheel setup for my bike (send the hate mail), I've been planning on one day changing for the FJR1300 rear swingarm (but that seems like a boatload of work) I got this crazy idea though, is there any way to make the FJR1300 rear wheel install onto the factory XS11 swingarm?
  • Hideki
    • 85
    • West Hills, CA
    Here's a pic of either side of the FJR's wheel. I'd actually love to swap the whole swingarm, but fabrication wise what a pita. I'm sorta tempted to buy a wheel and see if I can make it work anyone have any input? But when I say input I really don't just want opinions on whether it would look good, blah blah
      That wheel looks a bit wide to fit in the stock swingarm. It will barely accept a 140 tire.
      • tinman905
        • Aug 2007
        • 946
        • Orangeville,Ontario ,Canada
        That's a pricey wheel , you can find cheaper ones on Ebay. It will take a lot of work but if your handy with tig or mig welding you should have no problem fitting a FJR swing arm. The middle drive will need spacer also something like 30mm .There are a few threads about this swap and I believe there are a couple of people that started but haven't heard much for a while now.
        I was planning on doing the same but might just go to a chain drive conversion first. I picked up my 2005 FJR1300 for $39.95 off Ebay but haven't had the time to start it yet.
        BDF Special
